Skynet My internet speed dropped with Skynet on
sleeps1007
I have 1Gb speed and I average 850-950 Mb but when I turned on Skynet my speedtest would drop between 320-350Mb. Is there anything within Skynet that would allow me to get my original speeds?
Did you set up a swap file on the ssd?
Model? Firmware? Sounds like HW acceleration maybe.
When you enable both inbound and outbound filtering (Option 11 -> 4 ), then your speed will drop. If you only enable outbound filtering, then you will regain semi-normal speeds. This is normal, and by design, and been doing this since the beginning of time.
Ah ok I did change it and did see me speeds increase some. If it can't be helped then I either have to stick with it or remove it
