N66U + Huawei 658 v2 martian packets / dnsmasq[3803]: possible DNS-rebind attack detected: dns.msftncsi.com
FCM
Hello,
I have a N66U set up as AP router with public IP behind a Huawei 658 v2 ADSL router set up in bridge mode.
A linux box connected to the N66U keeps logging martian packets for the interface attached to that lan:
kernel: IPv4: martian source 192.168.100.51 from 192.168.100.51, on dev eno2
kernel: ll header: 00000000: c0 06 c3 02 95 d6 78 24 af 99 36 60 08 00
The two MACs mentioned are for the eno2 interface and the router respectively.
Additionally, the N66U router logs the following error:
Now comes the interesting part: the Huawei router when used in AP / DHCP server / standalone mode would try to install it's own security certificate for SSL connections: SSL connections I had this prompt pop up when accesing my Outlook inbox, never installed it of course as I found it weird :).
On top of that, the Huawei would also randomly open a page to
dns.msftncsi.com
which is some kind of keep alive address from Microsoft? I've seen this triggered for a brief period via the N66U when it was set up behind the Huawei with double NAT
I believe the issues are somehow related and the Huawei router is still trying some shenanigans even though it no longer acts as a DHCP server (it is disabled in its interface) and the N66U reports public WAN.
How should I investigate this further?
Please not that due to ISPs present in my area, I can't simply switch to another provider / plan to get rid of this issue.
Any help appreciated.
This is completely wrong. You should never have an access point connected directly to the public internet.
I might have used the wrong nomenclature, but this setup is similar to what I've typically used in the past where I would connect via PPPoE from my ASUS router and that router would get a public IP for it's WAN interface and then preform NAT for it's clients. What's wrong with this setup?
LAN IP: 192.168.100.1
WAN IP: 90.95.xxx.xxx
I've seen this recently since the IPv6 (AAAA) result for dns.msftncsi.com is considered a private address that would be considered a rebind attack by dnsmasq.
Add this line to /jffs/configs/dnsmasq.conf.add if you're running Merlin:
rebind-domain-ok=dns.msftncsi.com
How strange. What AAAA address is it returning that is private? I get fd3e:4f5a:5b81::1 which isn't private, unless there's been some change I'm not aware of.
Added the entry, no more dns-rebind attack.
As for the martian packets: I removed netplan from the linux box and I'm using NetworkManager instead. Edited the interface metric via nmcli. No more martian packets in syslog.
B DSL-N66U Probably a stupid question ASUS N Routers & Adapters 3
