Name resolution in home network
henrikk
So, what are my options when using the RT-N66U for getting name resolution insider the "home" network? One option it to install a full DNS server on a machine and point the RT-N66U DNS to it. Are there any easier alternatives? I do not see dnsmasq anywhere in the RT menus. Is that an option?
I would like internal name resolution on Mac, Linux and (maybe) Windows systems.
Any suggestions?
- Henrik
Any suggestions?
Hi Henrik,
The 'hosts' file shall become your best friend to accomplish the name resolution on all platforms... :rolleyes:
I do the same: One hosts file is holding all my device names and IP addresses.
Of course you need to have fixed IP address asignments: Either on the devices or on the router (via DNS server).
With kind regards
Joe :cool:
Any suggestions?
- Henrik
The router already does LAN name resolution through dnsmasq. Just make sure you do specify a local domain (for example blah.lan). You will then be able to resolve your computers by their hostnames (pc1.blah.lan).
Thank you Merlin. That is what I needed to know... and I have verified it works for me.
Thanks!
-Henrik
before upgrading to beta1 I just could reach my 2 linux samba server by using the names of the server.
now I use dhcp with manual assignment and I can only reach them by IP not with name anymore.
Can someone tell my why?
Where do I specify the local domain?
lost...
\edit
by using nslookup command in win7, i get the correct ip when i type the name of the server, but not when i ping the name ....
\update
since it worked from other computers ... it obviously was a bad software (toolbar addon and stuff) which broke windows. This helped:
Reset WINSOCK entries to installation defaults : netsh winsock reset catalog
Reset TCP/IP stack to installation defaults : netsh int ip reset reset.log
Flush DNS resolver cache : ipconfig /flushdns
Flush routing table : route /f (reboot required)
source:
http://superuser.com/questions/495759/why-is-ping-unable-to-resolve-a-name-when-nslookup-works-fine
