Carnagerover
Hi all,
Recently bought a Dlink DNS-323 and put to 1TB drives in for streaming media, I have the NAS connected via a Gigabit switch to my PC and when transferring files to the NAS i get around 16-17MBps and when copying off of the NAS around 19MBps according to vista.
However when i play a WMV file that i have that is 1080p from the NAS to my PC i get little pauses when watching the film, i have not watched it from the start as i skipped to the bit i wanted to watch, however once skipped forward i get little pauses in the video.
I have the NAS mapped on my PC, when i play this file on my PC i get no such pauses when i have skipped forward and it plays fine.
The computer has Gigabit connection and the specs are the following;
Quad Core Q6600 and 3.0Ghz
4GB of DDR 1066
Windows Vista
So i know that my PC is not to blame, what i cant understand is if i can write files at 17MBps and read them at 19MBps then what is causing the pauses as there is no video available that uses 152mbps i mean bluray tops out at 50mbps which is less than 6.25 MB/s
I have tried plugging the NAS into my machine directly but i still get the pauses, here is some info on the file i am trying to play;
File size : 7.84 GiB
Duration : 2h 1mn
Overall bit rate mode : Variable
Overall bit rate : 9 224 Kbps
Maximum Overall bit rate : 14.7 Mbps
Encoded date : UTC 2008-10-22 21:22:18.471
Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Description of the codec : Windows Media Video 9 Advanced Profile
Duration : 2h 1mn
Bit rate mode : Variable
Bit rate : 8 542 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.172
Language : en-us
Audio
Format : WMA3
Format profile : M2
Codec ID : 162
Codec ID/Info : Windows Media Audio 3
Description of the codec : Windows Media Audio 10 Professional - 640 kbps, 48 kHz, 5.1 channel 24 bit 1-pass CBR
Duration : 2h 1mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Language : en-us
The Maximum overall bit rate is 14.7Mbps, is that to much to steam over a normal mapped share ?
Dont understand what the problem is ?
Any help would be ideal
4GB of DDR 1066
Windows Vista
Duration : 2h 1mn
Video
Format : VC-1
Codec ID : WVC1
Duration : 2h 1mn
Colorimetry : 4:2:0
Language : en-us
Audio
Format : WMA3
Format profile : M2
Codec ID : 162
Duration : 2h 1mn
Bit rate : 640 Kbps
Language : en-us
