Native IPV6 problems on TWC, poor DNS response time, upload buffer bloat.
PabloAbonia
I am running native IPV6 on Time Warner, and I am running into problems of prolonged
DNS lookup times when checked with netalyzr (170ms), along with problem of upload buffer bloat times (upto 1 s on DSL Reports). While QOS will improve my downloads, nothing clearly fixes the download nothing I've done has corrected the upload latency issue regularly.
I have grown suspicious of the IPV6 DNS settings, as on Time Warner I have fe80 addresses for my gateway addresses:
IPv6 Connection Type: Native with DHCP-PD
WAN IPv6 Address: 2605:NATIVE_ADD/128
WAN IPv6 Gateway: fe80::GATEWAY <--- CAN ONLY PING ON eth0
LAN IPv6 Address: 2605:ROUTER::1/64
LAN IPv6 Link-Local Address: fe80::INTERNAL_ROUTER/64 ping on br0
DHCP-PD: Enabled
LAN IPv6 Prefix: 2605:PREFIX/64
DNS Address: fe80::INTERNAL_DNS_SERVER
Traceroute to anywhere, and from any device (including the router) fails on the first hop.
Traceroute to the WAN IPV6 fe80 Address fails, however I can still ping the address
via eth0 on the router.
One >>key<< point about that pinging the fe80 WAN IPV6 address, is that it takes up to 8 ms on a CAT6 cable from the router to the modem. All the other internal devices typically ping in the <1ms range regularly.
I think the use of fe80 addresses as gateways may be responsible for some of
the delays.
Thoughts,
Pablo
