What is "echo support".My wife bought a TP-Link Smart Wifi plug. When it arrived I looked at it and told her it will not work as we don't support 2.4GHz. I need 5GHz as I don't run 2.4 GHz any more. Does anybody use one of these? I need 5GHz and echo support.
I thnk he's looking for a smart plug, Cap'n.I bought a TechToo USB ACWiFi adapter
Echo is Amazon's Alexa voice control. My wife uses it every day.
I just thought maybe we don't need WIFI and we could just use POE directly to automate home devices. Are there any POE devices which can control lights and such? Alexa could issue Ethernet requests and the devices would work across POE. I think this would make the device even cheaper because no wireless needs to built in to the device.
The thing about POE is it is easy as all the smart devices run off 110v so they are already connected to your local power system.
Thread starter | Title | Forum | Replies | Date |
S | Smart home behavior | General Smart Home Discussion | 3 | |
M | Local (WiFi) access to Sensi Thermostat | General Smart Home Discussion | 2 |
Welcome To SNBForums
