Need wireless n and pc wifi card that can reach 100 Ft.
little_scrapper
What would be the best combo for this situation. A wireless n router that can reach from one building to the next building which is about 80-100 ft. away. Ceiling to floor glass and clear line of sight (aside from the glass in both buildings). And a wifi card (or something) for the pc that can reach back.
Need specific examples. Considering a Cisco AP solution @ about $800 but want to know if it can be done reliably with consumer grade equip. Like a WNDR3700 and ...some wifi card.
Does not need to have great bandwidth. Only need to be able to access email.
If you have line of sight for both ends of the link and there is no metalized coating on the glass (for solar control)' any card and router should work.
Would you by chance have any insight into the degree of signal degredation that would occur if both glass walls were in fact tinted?
No. But it is only coating that will knock down the signal.
