NetData/YAMon3 Installation Help
SingingHobo
Good morning.
I've recently acquired an Asus RT-AC86u to replace a failing/outdated D-Link router. I've successfully installed the most recent Asuswrt-Merlin build (382.1_2) and have been running strong for about 24hrs without issue.
Today; I've begun the process of attempting to get either (or both) NetData and YAMon3 installed.
I've followed the Entware-NG guide for installation and did not experience any issues. My pre-formatted EXT2 USB drive (2GB) is installed into the router.
From there, I installed NetData and I get the error message:
"Access to file is not permitted: /opt/share/netdata/web/"
Regarding YAMon3 - all indications are that it is running. Having installed it successfully on the D-Link router, I can run the installer to /opt/YAMon3 and there are no errors. /tmp/YAMon3.3-running exists in /tmp/ but accessing the site gives me a 404 error.
I've done some searching and haven't come across a solution to either of these issues.
In troubleshooting I've removed Entware-NG and re-installed. I've re-installed NetData and have the same results as prior (access error).
I'd love some guidance from anyone who has encountered similar.
Thanks.
Edit
netdata.conf
[web]
 web files owner = admin
 web files group = admin
 # default port = 19999
 # bind to = *
change to
[web]
 web files group = root
 # bind to = *
and restart netdata.
Also I recall you should disable 'python.d' and beware that there is a thread recommendation to reduce the logging for fear of wearing out NAND.
hi, after starting up of netdata, i got a bunch of messages like this
Oct 10 16:22:48 netdata[11696]: DEVICE-MAPPER ('mtdblock3', 31:3): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
Oct 10 16:22:48 netdata[11696]: DEVICE-MAPPER ('mtdblock4', 31:4): Cannot open directory '/dev/mapper'. Disabling device-mapper support.
Oct 10 16:22:48 netdata[11696]: DEVICE-MAPPER ('mtdblock4', 31:4): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
Oct 10 16:22:48 netdata[11696]: DEVICE-MAPPER ('sda', 8:0): Cannot open directory '/dev/mapper'. Disabling device-mapper support.
Oct 10 16:22:48 netdata[11696]: DEVICE-MAPPER ('sda', 8:0): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
Oct 10 16:22:48 netdata[11696]: DEVICE-MAPPER ('sda1', 8:1): Cannot open directory '/dev/mapper'. Disabling device-mapper support.
Oct 10 16:22:48 netdata[11696]: DEVICE-MAPPER ('sda1', 8:1): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
Oct 10 16:22:48 netdata[11696]: DEVICE-MAPPER ('sda5', 8:5): Cannot open directory '/dev/mapper'. Disabling device-mapper support.
Oct 10 16:22:48 netdata[11696]: DEVICE-MAPPER ('sda5', 8:5): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
Oct 10 16:22:48 netdata[11696]: DEVICE-MAPPER ('sda6', 8:6): Cannot open directory '/dev/mapper'. Disabling device-mapper support.
Oct 10 16:22:48 netdata[11696]: DEVICE-MAPPER ('sda6', 8:6): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
Oct 10 16:22:48 netdata[11696]: PROCFILE: Cannot open file '/proc/net/rpc/nfsd'
Oct 10 16:22:48 netdata[11696]: PROCFILE: Cannot open file '/proc/net/rpc/nfs'
Oct 10 16:22:48 netdata[11696]: PROCFILE: Cannot open file '/proc/spl/kstat/zfs/arcstats'
Oct 10 16:22:48 netdata[11696]: BTRFS: Cannot open directory '/sys/fs/btrfs'.
Oct 10 16:23:09 netdata[11696]: CGROUP: cannot read directory '/sys/fs/cgroup/cpuacct'
Oct 10 16:23:09 netdata[11696]: CGROUP: disabled cpu statistics.
Oct 10 16:23:09 netdata[11696]: CGROUP: cannot read directory '/sys/fs/cgroup/blkio'
Oct 10 16:23:09 netdata[11696]: CGROUP: disabled blkio statistics.
Oct 10 16:23:09 netdata[11696]: CGROUP: cannot read directory '/sys/fs/cgroup/memory'
Oct 10 16:23:09 netdata[11696]: CGROUP: disabled memory statistics.
Oct 10 16:23:09 netdata[11696]: CGROUP: cannot read directory '/sys/fs/cgroup/devices'
Oct 10 16:23:09 netdata[11696]: CGROUP: disabled devices statistics.
what might a problem ? gui is showing empty grapsh
AC86u YAMon3 installed.
wow, i'd love to read about any success you have with this.
the one thing i miss most from my linksys wrt is yamon3.
i just assumed on asus+merlin it would not work at all.
update: so i got yamon3 working fine on my ac3100
