Network Icons
toor
So the asus routers have some built in vendor icons that you cant choose and seem to be automatic. But does anyone know of a way that we could pick them?
http://192.168.1.1/images/New_ui/networkmap/vender-list.png
http://192.168.1.1/images/New_ui/networkmap/vender-listover.png
These are the vendor icons and here is the ones that are listed when you want to change.
http://192.168.1.1/images/New_ui/networkmap/client-list.svg
So, is the only way to pick them would be to copy the files and edit it manually?
You can change them and add your own. Click on the Clients logo, than click on the icon for the device you're interested in. The pop-up window will show you the icon which you can set to default or click change. When you click Change you're presented with the list and can click the + to add your own from your computer.
Here are some from other posts on the forum:
http://www.iconarchive.com/tag/asus-router
http://postimg.org/gallery/s2kxd2k4/
Using photo editor I created a 85x85 pixel .png file for one of my devices. Seems to work nice. It's just up to you (your editor skills) how cool it looks.
