New firmware version check - push notification
goaspy
Hi, is there a way to run a script that will send a Pushover notification whenever a new stable version is found?
I have the new version check option enabled, but I don't know if it's triggered by a web login or runs periodically.
If it runs periodically then it should be able to trigger a custom script. The only complication I see in this case is to send the message only once, and the script would have to store a last notified version number somewhere.
and for pushover well all you need is to add, tweak it your needs to fit the script instead of email it can send a push
function push {
   curl -s -F "token=YOUR_TOKEN_HERE" \
   -F "user=YOUR_USER_KEY_HERE" \
   -F "title=YOUR_TITLE_HERE" \
   -F "message=$1" https://api.pushover.net/1/messages.json
push "It worked\!"
There's a custom script that gets run on new firmware availability. It's documented in the Changelog, but I forgot to add it to the Wiki after that version went out of beta. Check the Changelog for more info. I also posted a sample GMail script in the 380.65 alpha thread here on the forums.
i could volunteer to do a updated sample with pushover and pushbullet notifications planning to do a personal script anyways then i can add it to the wiki
tested script :p based on Rmerlins sample script
#!/bin/sh
use_email="disabled"                                    # enabled / disabled (default: disabled)
use_pushbullet="disabled"                               # enabled / disabled (default: disabled)
use_pushover="disabled"                                 # enabled / disabled (default: disabled)
#Pushbullet/Pushover settings
pushbullet_token=""                                     # Your access token here (https://docs.pushbullet.com/)
pushover_token=""                                       # Your access token here (https://pushover.net/api)
pushover_username=""                                    # Pushover User ID (the user/group key (not e-mail address often referred to as USER_KEY)
# email settings
SMTP="smtp.gmail.com"
PORT="465"
USERNAME=""
PASSWORD=""
# Mail Enveloppe
FROM_NAME=""
FROM_ADDRESS=""
TO_NAME=""
TO_ADDRESS=""
### Do not change below
# Retrieve version
TMPVERS=$(nvram get webs_state_info)
VERS=${TMPVERS:5:3}.${TMPVERS:8:10}
ROUTER_IP=$(nvram get lan_ipaddr)
email_message () {
echo "From: \"$FROM_NAME\" <$FROM_ADDRESS>" > /tmp/mail.txt
echo "To: \"$TO_NAME\" <$TO_ADDRESS>" >> /tmp/mail.txt
echo "Subject: New router firmware notification" >> /tmp/mail.txt
echo "" >> /tmp/mail.txt
echo "New firmware version $VERS is now available for your router at $ROUTER_IP." >> /tmp/mail.txt
curl --url smtps://$SMTP:$PORT \
  --mail-from "$FROM_ADDRESS" --mail-rcpt "$TO_ADDRESS" \
  --upload-file /tmp/mail.txt \
  --ssl-reqd \
  --user "$USERNAME:$PASSWORD" --insecure
rm /tmp/mail.txt
pushover_message () {
curl -s \
  --form-string "token=$pushover_token" \
  --form-string "user=$pushover_username" \
  --form-string "message=New firmware version $VERS is now available for your router at $ROUTER_IP." \
pushbullet_message () {
text="New firmware version $VERS is now available for your router at $ROUTER_IP."
title="$USER@$HOSTNAME"
curl -s -u $pushbullet_token: -X POST https://api.pushbullet.com/v2/pushes --header 'Content-Type: application/json' --data-binary '{"type": "note", "title": "'"$title"'", "body": "'"$text"'"}' >/dev/null 2>&1
     if [ $use_pushbullet = "enabled" ]; then
        pushbullet_message
     fi
     if [ $use_pushover = "enabled" ]; then
        pushover_message
     fi
     if [ $use_email = "enabled" ]; then
        email_message
     fi
Thanks for your help, I've got it working, at least manually for now, I just have to wait for a new release :)
I was getting this error at first, "curl: option -F: is badly used here", but I've changed it using an example from pushover and it works fine now:
curl -s \
One last thing, I've named the script "update-notification", as mentioned in the changelog, and I've placed it in "/jffs/scripts". I should now get notifications every 48h until I switch to the new version.
Cheers!
