Soulless Daedra
Recently I had purchased an asus
RT-AC51U Router to upgrade from my current Sky Hub 2 router/modem. It was all going great for a while, my set up was to plug in a cat 7 RJ 45 from a LAN port of the Sky Hub into the Asus Routers WAN port, as not to break the TAC of Sky.
Also giving the Asus router a reserved IP and making it the DMZ server and opening the ports 67 and 68. All in the Sky Hub.
The 5G does not work well at all though but this is not my issue.
My issue stemmed quite recently, the log of the Asus router has started to flood with this error:
_rules: apply the nat_rules(/tmp/nat_rules_vlan2_vlan2)!
Feb 8 22:04:40 WAN Connection: ISP's DHCP did not function properly.
Feb 8 22:04:40 stop_nat_rules: apply the redirect_rules!
Feb 8 22:04:46 WAN Connection: WAN was restored.
Feb 8 22:04:46 start_nat_rules: apply the nat_rules(/tmp/nat_rules_vlan2_vlan2)!
Feb 8 22:08:38 WAN Connection: ISP's DHCP did not function properly.
Feb 8 22:08:38 stop_nat_rules: apply the redirect_rules!
Feb 8 22:08:42 WAN Connection: WAN was restored.
Feb 8 22:08:42 start_nat_rules: apply the nat_rules(/tmp/nat_rules_vlan2_vlan2)!
Feb 8 22:08:59 kernel: rt2860v2:ASSOC - Assign AID=9 to STA dc:41:5f:39:64:50
Feb 8 22:09:43 WAN Connection: ISP's DHCP did not function properly.
Feb 8 22:09:43 stop_nat_rules: apply the redirect_rules!
Feb 8 22:09:46 WAN Connection: WAN was restored.
Feb 8 22:09:46 start_nat_rules: apply the nat_rules(/tmp/nat_rules_vlan2_vlan2)!
I have tried restarting the modem and the router with no luck! Please could someone attempt to help me if you can. Thank you
