Skynet New Skynet v8.0.9 Release
No such error here, but on your advice reinstalled (cos, you never know).
Getting the same error repeating, does not survive a reboot and entire Skynet tab goes missing.
I have to uninstall again and wait for fix.
Same here, not seeing obvious errors. Apart from the Ranges banned entries I only saw these initially:
Nov 13 21:33:23 Skynet: [*] USB Not Found - Sleeping For 10 Seconds ( Attempt 1 Of 10 )
Nov 13 21:34:07 Skynet: [*] WebUI Integration Requires Logging To Be Enabled
Unfortunately I also updated it (obviously), so now it doesn't work for me either, but the installation script also gives an error :( this update was hasty.. How to proceed?
Might be useful if you could post the error from the log please?
All results should go to Adamm's post, here:
There is still a problem with 8.0.2.
After updating Skynet, switching to the custom filter list and a reboot, I could not connect to the router via my PC.
Although, I could connect to the router with my smartphone.
I need to investigate further, to narrow things down.
I can't reproduce this with the list your using. Skynet logs every packet it drops, that also holds true in situations like this.
skynet@GT-BE98-38A4:/tmp/home/root# firewall banmalware https://raw.githubusercontent.com/jumpsmm7/GeneratedAdblock/master/filter.list
# Router Firewall And Security Enhancements #
# By Adamm - https://github.com/Adamm00/IPSet_ASUS #
# 16/11/2025 - v8.0.2 #
Custom Filter Detected: https://raw.githubusercontent.com/jumpsmm7/GeneratedAdblock/master/filter.list
Downloading filter.list | [0s]
Refreshing Whitelists | [9s]
Start Blacklist Consolidation |
[✔] Downloading https://iplists.firehol.org/files/spamhaus_edrop.netset
[✔] Downloading https://iplists.firehol.org/files/firehol_level2.netset
[✔] Downloading https://iplists.firehol.org/files/et_block.netset
[✔] Downloading https://iplists.firehol.org/files/cybercrime.ipset
[✔] Downloading https://iplists.firehol.org/files/et_spamhaus.netset
[✔] Downloading https://iplists.firehol.org/files/firehol_level1.netset
[✔] Downloading https://iplists.firehol.org/files/bds_atif.ipset
[✔] Downloading https://iplists.firehol.org/files/dyndns_ponmocup.ipset
[✔] Downloading https://iplists.firehol.org/files/greensnow.ipset
[✔] Downloading https://iplists.firehol.org/files/et_compromised.ipset
[✔] Downloading https://iplists.firehol.org/files/spamhaus_drop.netset
[✔] Downloading https://iplists.firehol.org/files/firehol_level3.netset
[✔] Downloading https://iplists.firehol.org/files/dshield_1d.netset
[✔] Downloading https://raw.githubusercontent.com/SecOps-Institute/Tor-IP-Addresses/master/tor-exit-nodes.lst
[✔] Downloading https://iplists.firehol.org/files/malc0de.ipset
[✔] Downloading https://raw.githubusercontent.com/stamparm/ipsum/master/levels/1.txt
[✔] Downloading https://iplists.firehol.org/files/dshield.netset
[✔] Downloading https://iplists.firehol.org/files/normshield_high_attack.ipset
[✔] Downloading https://raw.githubusercontent.com/jumpsmm7/GeneratedAdblock/master/IPlist.list
[✔] Downloading https://feodotracker.abuse.ch/downloads/ipblocklist.txt
[✔] Downloading https://iplists.firehol.org/files/urlvir.ipset
[✔] Downloading https://iplists.firehol.org/files/bi_any_2_30d.ipset
[✔] Downloading https://iplists.firehol.org/files/coinbl_hosts_browser.ipset
[✔] Downloading https://iplists.firehol.org/files/alienvault_reputation.ipset
[✔] Downloading https://iplists.firehol.org/files/iblocklist_spamhaus_drop.netset
[✔] Downloading https://iplists.firehol.org/files/blocklist_net_ua.ipset
[✔] Downloading https://iplists.firehol.org/files/iblocklist_pedophiles.netset
[✔] Downloading https://iplists.firehol.org/files/normshield_high_bruteforce.ipset
[✔] Downloading https://iplists.firehol.org/files/iblocklist_ciarmy_malicious.netset
[✔] Downloading https://iplists.firehol.org/files/myip.ipset
[✔] Downloading https://lists.blocklist.de/lists/strongips.txt
[✘] Failed to fetch: https://www.talosintelligence.com/documents/ip-blacklist
[✔] Downloading https://rules.emergingthreats.net/fwrules/emerging-Block-IPs.txt
[✘] Failed to fetch: https://myip.ms/files/blacklist/general/latest_blacklist.txt
[✔] Downloading https://darklist.de/raw.php
[✔] Downloading https://sigs.interserver.net/iprbl.txt
[✔] Downloading https://blocklist.greensnow.co/greensnow.txt
[✔] Downloading https://iplists.firehol.org/files/ciarmy.ipset
[✔] Downloading https://voipbl.org/update
[✔] Downloading https://www.blocklist.de/downloads/export-ips_all.txt
Finish Blacklist Consolidation | [23s]
Applying New Blacklist | [4s]
Refreshing AiProtect Bans | [1s]
Saving Changes | [2s]
For Whitelisting Assistance -
https://www.snbforums.com/threads/r...wall-security-enhancements.16798/#post-115872
[#] 336301 IPs (+303646) -- 21573 Ranges Banned (+19250) || 1955 Inbound -- 0 Outbound Connections Blocked! [banmalware] [40s]
You do, because i can't replicate this.
Which blocklist are you trying to use?
@Adamm :
Thanks for the hard work and dedication!
Still see on GitHub your open issue suggestion with @dave14305 on v8.0.5?
