No data in Traffic Monitor Global
Khadanja
RT-AC68U running 384.14.2
No data in Traffic Monitor Global daily or monthly!! Real time & Last 24 hour shows graph. Have already tried resetting the data file.
No data in Traffic Monitor Global daily or monthly!! Have already tried resetting the data file.
I just checked the data files & it seems file size is too small so looks like nothing is being written, hasn't changed from 4 Kb. What am I doing wrong? Have already tried re creating the data files.
q@RT-AC68U-20E0:/tmp/mnt/RT-AC68/Trffic# du -sh -- *
4.0K tomato_cstats_1831bf4a20e0.gz
4.0K tomato_rstats_1831bf4a20e0.gz
My files are 355 and 401 bytes respectively. Output from the du command shows the same result as yours (4.0K). I have stats. So the file size doesn't appear to be relevant to the issue.
Thanks. What are your other settings? Am I missing something? Real time & last 24 hour shows which is weird? Also if I turn on Traffic Analyser that shows data. I don’t really want to do a factory reset but can if I have to. Maybe @RMerlin can help.
I have Traffic Analyzer on and I have my Stats setup to save on a USB 2.0 drive.
Have you got AiProtection or QOS enabled? I’m wondering if it’s dependant on any of these as I have both turned off.
