NO Internet?
JT Strickland
Some of my clients have internet but most don't. I have a 1G up & down fiber line that checks OK. I rebooted my router, and it still hasn't synced with NTP time server. I lost all my scripts. Second reboot, same thing.
Any suggestions?
Unplug the power from the router. Remove all USB devices. Wait a couple of minutes. Power it up.
Disable "JFFS custom scripts and configs" in the GUI (Administration - System) and reboot. Then start to diagnose the problem. The first thing I would check is that the USB drive isn't corrupted and is mounting OK.
Done. No change yet. Not looking good. Still hasn't synced time.
Done. Usb seems OK, mounted ok. Scan doesn't show anything. Still some clients have no interenet, time hasn't synced. A lot of "*kernel:dropped*" in the log.
Check your WAN DNS settings are pointing to your ISP's servers or some other public servers, not any internal servers.
says "DNS Server: 9.9.9.11, 149.112.112.112"
Probably normal because you had Skynet installed which I think enables logging of dropped packets.
That should be OK. What have you got set as the router's primary and secondary NTP Servers?
How about doing this from the router's command line:
date
service restart_ntpd
sleep 10; date
EDIT: Is it simply that your ISP connection is down? Check that your router has a working internet connection (does it say Disconnected on the Network Map?). Can the router ping 8.8.8.8? You said some clients still work - are these mobile devices that are failing over to an LTE connection perhaps?
date
sleep 10; date
pool.ntp.org, no secondary set
Code returned May 5 01:26:25 CTD 2018
It says Connected. ISP connection appears good, they say it is. ping was good, till I broke it at 34 packets.
Is anything left but a factory reset? I need to take some screenshots.
I somehow doubt a factory reset will change anything if this was working OK until today.
Try running ntpd from the command line using different servers and see if it succeeds:
Rich (BB code):
# /usr/sbin/ntp -dnqt -p time.google.com -p time.windows.com
ntp: 'time.google.com' is 216.239.35.4
ntp: 'time.windows.com' is 51.145.123.29
ntp: sending query to 51.145.123.29
ntp: sending query to 216.239.35.4
ntp: reply from 51.145.123.29: offset:-55753.128328 delay:0.017101 status:0x1c strat:3 refid:0x00e64219 rootdelay:0.008026 reach:0x01
ntp: reply from 216.239.35.4: offset:-55753.124094 delay:0.024566 status:0x24 strat:1 refid:0x474f4f47 rootdelay:0.000000 reach:0x01
ntp: reply from 51.145.123.29: offset:-55753.128411 delay:0.017173 status:0x1c strat:3 refid:0x00e64219 rootdelay:0.008026 reach:0x03
ntp: setting time to 2022-09-01 18:30:52.502441 (offset -55753.128411s)
Rich (BB code):
It returned "ntp: bad address 'time.google.com' " etc etc etc
Strange. Sounds like your DNS isn't working.
Try:
nslookup www.google.com
nslookup www.google.com 8.8.8.8
nslookup www.google.com 9.9.9.11
and
cat /etc/resolv.conf
cat /tmp/resolv.dnsmasq
Have you also tried rebooting (don't shut down, then start again, that is not the same thing) the problem clients?
yes, several times with some.
Try:
and
returned:
Surveyor@RT-AX86U-CB28:/tmp/home/root# nslookup www.google.com Server: 9.9.9.11 Address 1: 9.9.9.11 nslookup: can't resolve 'www.google.com' Surveyor@RT-AX86U-CB28:/tmp/home/root# nslookup www.google.com 8.8.8.8 Server: 8.8.8.8 Address 1: 8.8.8.8 dns.google Name: www.google.com Address 1: 64.233.177.99 yx-in-f99.1e100.net Address 2: 64.233.177.147 yx-in-f147.1e100.net Address 3: 64.233.177.105 yx-in-f105.1e100.net Address 4: 64.233.177.104 yx-in-f104.1e100.net Address 5: 64.233.177.103 yx-in-f103.1e100.net Address 6: 64.233.177.106 yx-in-f106.1e100.net Address 7: 2607:f8b0:4002:81a::2004 atl14s20-in-x04.1e100.net
I lost my prompt after google.com 9.9.9.11
Can't break or exit out of putty
Just close the program window and open a new one.
So far it's sounding like either a) an intermittent internet problem with your ISP, or b) an inability to reach Quad9's servers.
Try and complete the outstanding commands from my previous post. After that try changing your WAN DNS servers to 8.8.8.8 and 8.8.4.4
returned
ASUSWRT-Merlin RT-AX86U 386.7_2 Sun Jul 24 21:37:08 UTC 2022 Surveyor@RT-AX86U-CB28:/tmp/home/root# cat /etc/resolv.conf nameserver 9.9.9.11 nameserver 149.112.112.112 nameserver 127.0.1.1 Surveyor@RT-AX86U-CB28:/tmp/home/root# cat /tmp/resolv.dnsmasq server=127.0.1.1 Surveyor@RT-AX86U-CB28:/tmp/home/root#
That did sync ntp time after setting WAN DNS servers to google
returned
Ok, so it looks like a problem with Quad9's servers (or your ISP).
I'm not sure why you've got Stubby's IP address in your resolv file. I guess it's because you've enabled the VPN client in Exclusive mode and have DoT enabled as well?
I've got DoT enabled, but no VPN clients unless its an unused leftover or something. I had a VPN server. It's still showing the Quad9's as WAN DNS servers. Maybe a reboot will cure that. Still don't have internet for some clients. They are all present on the local network, they just don't have internet. I wonder if I could get by with Quad9's "normal" servers? Maybe they took those out for something.
