NordVPN custom configs
sl4fko
Here is NordVPN default custom config:
resolv-retry infinite
remote-random
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
ping 15
ping-restart 0
ping-timer-rem
remote-cert-tls server
pull
fast-io
cipher AES-256-CBC
Sometime ago I found a bit different one here on forum:
remote-random
ping 15
ping-restart 0
ping-timer-rem
persist-key
persist-tun
reneg-sec 0
fast-io
disable-occ
mute-replay-warnings
auth-nocache
sndbuf 524288
rcvbuf 524288
push "sndbuf 524288"
push "rcvbuf 524288"
pull-filter ignore "auth-token"
pull-filter ignore "ifconfig-ipv6"
pull-filter ignore "route-ipv6"
explicit-exit-notify 3
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
Is there any gain in one or another? What are the differences? Any other ideas for config?
Thanks!
Yes, at the bottom. I am not shure for all of them, but the parameters are specific for every VPN provider.
C nordvpn configuration VPN 4
P R9000 with Voxel's Custom firmware Unable to connect via TUN VPN 5
