OpenVPN with PIA
jonnyk9
anyone know how to set this up properly?
Here's my log:
Feb 19 16:46:03 notify_rc : start_vpnclient1
Feb 19 16:46:03 openvpn[634]: Options error: You must define CA file (--ca) or CA path (--capath)
Feb 19 16:46:03 openvpn[634]: Use --help for more information.
I followed the vpn's directions for setup and it is exactly the same as tomato's setup.
https://www.privateinternetaccess.c...-setup-for-newer-branches-including-tomatousb
Not sure what i'm doing wrong...
Any help is appreciated.
Using Merlin's newest build: RT-N66U_3.0.0.4_270.24.trx
TIA
The CA aka Certificate Authority can be pasted in the webui on the OpenVPN Keys page.
I pasted the VPN's ca.crt file contents into the certificate key text area of the setup initially and that's the error I get.
When you are on the OpenVPN-Keys tab make sure you select Client 1 from the drop down menu.
Cheers
hehe. i know there must have been a stupid reason why this would not work. you're right... i add the ca to the server1 drop down and not to the client1 dropdown.
working great now and this is favourite firmware!!!
thanks!
go to VPN->OpenVPN client->Authorization Mode row
you'll see a link for "Content modification of Keys & Certificates"
go in there and paste the contents of ca.crt into the certificate authority section.
THanks yea i finally seen that.. if it was a snake it would have bit me.
I pasted my ca cert client cert and client key in a window that popped up after i clicked that.
