Opt folder missing
Marko Polo
And not only opt, but media too
Entware reinstall did not help. It is a mounting problem or what?
Scripts in /jffs exist but I assume it's not the point.
Is that an AC86U?
bad quess, nvm
The media broken link is normal, it's a leftover from a standard linux install
The opt link should point to a second symlink in / tmp which points to your entware install location. What does a directory listing for / tmp show for opt?
(Spaces added for cloudfare)
And should I do any extra actions when replacing HDD or router must recognize entware installation out-of-the-box?
This issue happened after restoration of HDD backup from Clonezilla image, and soon I plan to replace HDD again.
