Entware /opt/lib/xxx.so.6: file too short on merlin firmware
tm4ig
I have asus ac86u router with asusmerlin 386.3_2 firmware and opkg package manager.
I have discovered that for some installed packages "/opt/lib/xxx.so.6: file too short" error has appeared. For All packages latests availible versions were installed.
For examle
RT-AC86U-C920:/tmp/home/root# htop
htop: error while loading shared libraries: /opt/lib/libncursesw.so.6: file too short
RT-AC86U-C920:/tmp/home/root# nano
nano: error while loading shared libraries: /opt/lib/libncursesw.so.6: file too short
RT-AC86U-C920:/tmp/home/root# mtr
mtr: error while loading shared libraries: /opt/lib/libncursesw.so.6: file too short
Everything worked normal early, how can I fix this problem?
The appropriate steps in the link below may help get your USB drive working properly again.
Before following them, I would safely remove the drive via the GUI. Format it in a PC with NTFS format. Then, check the 'Format the JFFS partition on next boot' box, and be sure you click the 'Apply' button at the bottom of the page before you reboot the router 3 times in the next 15 minutes.
Now, insert the USB drive (making sure you've formatted it as NTFS first) and follow the steps to properly format the drive as Ext4, create a 2GB swap file and enable the DC (disk checker) script before you re-install the scripts you want to use.
amtm Step-by-Step https://www.snbforums.com/threads/amtm-step-by-step-install-guide-l-ld.56237/#post-483421
