Parental control the SH way
itpp20
My own confoxtal the easy way (at least for me);
#!/bin/sh
# /jffs/scripts/services-start
cru a blockdev "30 22 * * sun,mon,tue,wed,thu sh /jffs/scripts/blockdev.sh"
cru a relall "0 7 * * * sh /jffs/scripts/relall.sh"
cru a relallwk "28 0 * * sun,sat sh /jffs/scripts/relall.sh"
cru a blockdevwk "30 0 * * sun,sat sh /jffs/scripts/blockdev.sh"
Control script:
#!/bin/bash
# /jffs/scripts/blockdev.sh
echo "#!/bin/bash">/jffs/scripts/relall.sh
echo "">>/jffs/scripts/relall.sh
chmod a+rx /jffs/scripts/relall.sh
# copy below block for other devices, copy MAC address from dhcp list from GUI asus
# Samsung(android)_My_Son
mmac=AA:BB:7B:C6:55:44
vmac=$(echo "$mmac" | awk '{print tolower($0)}')
kmmac=$(cat /var/lib/misc/dnsmasq.leases | grep "$vmac" | cut -d" " -f3)
if ! [ -z "${kmmac}" ]; then iptables -I FORWARD -s $kmmac -j DROP; fi
if ! [ -z "${kmmac}" ]; then conntrack -D --src=$kmmac; fi
if ! [ -z "${kmmac}" ]; then echo iptables -D FORWARD -s $kmmac -j DROP>>/jffs/scripts/relall.sh; fi
On school days cut off internet at 22:30, on weekends at 00:30, release all days at 07:00
# Example of Cron job definition:
# .---------------- minute (0 - 59)
# | .------------- hour (0 - 23)
# | | .---------- day of month (1 - 31)
# | | | .------- month (1 - 12) OR jan,feb,mar,apr ...
# | | | | .---- day of week (0 - 6) (Sunday=0 or 7) OR sun,mon,tue,wed,thu,fri,sat
# * * * * * user-name command to be executed
Have fun and be amazed your son/daughter wants to go to bed at 22:31 :cool:
The router's firmware doesn't have /bin/bash.
EDIT: The HND routers now have /bin/bash but it's only a symlink to busybox so there's still no support for bash specific commands (like arrays).
confoxtal?
Correct, but as it happens, it doesn't matter. The OP is calling sh and passing the script(s) as an argument, so it works. If only for reasons of clarity, the references to /bin/bash should probably be changed to /bin/sh.
Regardless, thanks for the script.
Hello,
Thank you ittp20 for sharing this. Very interesting.
From an intellectual standpoint, I like the idea of not "overloading" the router and not checking packets when there are no traffic restrictions.
I'm curious, have you by any chance, noticed a performance hit when using iptables to check the timeslots ?, with things like
iptables -t filter --insert FORWARD 2 -m time --timestart 00:00:00 --timestop 08:00:00 --kerneltz
Or were you more inclined to use cron anyway.
BTW: In my area, 400Mbps is the best consumers can get at the moment. So, not Gbps for us so far. I guess it depends a lot on how much/fast you need to get from the router/line.
Best regards
Take care
W.
Cron(winscp) is easier to manage than iptables(ssh) and iptables by itself can't translate mac to ip and when the time comes he gets smart about changing mac I'll be 2 steps ahead by using cron :D
When it comes to GB on your LAN2WAN, my car can do 260kph but I see no point exceeding 140kph so in its lifetime it will be stuck at 140kph. The moral? whats the point in all those efforts in GB when you can do everything already with the 150-300? You can map the users one on one with problems and trying to get max on wifi.
Thats typical marketing BS turning you in to a lemming.
Thank you for the feedback. Neat solution.
