Port forward query
Wishmaster1965
I have 2 port forwards setup for a couple of apps on my PC but when is scan my port using my phone on 4g the specific port it shows closed.
Do I have to do an iptables command to get this to stick ?
ColinTaylor
Part of the Furniture
You can check whether the port forwarding rules are in effect by going to System Log - Port Forwarding.
Ports will show as closed in a scan if there isn't an application actively responding on that port or it's UDP.
Wishmaster1965
Fixed it but will need to check what I did.
