port forward (using iptables) woes
PedraSimon
Hi all,
Please help me with port forwarding with iptables, as port forwarding via web gui is not working.
Config:
I have 2 router in my setup.
RT-AC56S (IP addr: 172.17.2.1) as the gateway (GW), running asusWrt (3.0.0.4.376_3561).
RT-N16 (IP addr: 172.17.2.3) as access point (AP), running tomato shibby build 1.28.0000 MIPSR2-123.
I want to setup transmission (port:55115) to run on the AP. With my limited iptables knowledge, I think I need to add the following rules:-
iptables -I VSERVER --table nat -p tcp --dport 55115 -j DNAT --to 172.17.2.3:55115
iptables -I VSERVER --table nat -p udp --dport 55115 -j DNAT --to 172.17.2.3:55115
iptables -I FORWARD -d 172.17.2.3 -p tcp --dport 55115 -j ACCEPT
iptables -I FORWARD -d 172.17.2.3 -p udp --dport 55115 -j ACCEPT
The config page of Transmission still show the port 55115 as closed after adding the above rules. Online port tests also show the port as closed.
What did I do wrong?
Also, does anyone know why the data pkt passing through the VSERVER, ended up as counting 2 pkt in the FORWARD chain?
admin@(none):/tmp/home/root# iptables -t nat -L -v -n
Chain PREROUTING (policy ACCEPT 174 packets, 15469 bytes)
 pkts bytes target     prot opt in     out     source               destination
 7791  578K VSERVER    all  --  *      *       0.0.0.0/0            xxx.xxx.xxx.xxx
Chain INPUT (policy ACCEPT 101 packets, 11591 bytes)
Chain OUTPUT (policy ACCEPT 111 packets, 8248 bytes)
Chain POSTROUTING (policy ACCEPT 112 packets, 8308 bytes)
99389 6696K MASQUERADE  all  --  *      eth0   !xxx.xxx.xxx.xxx      0.0.0.0/0
 2391  244K MASQUERADE  all  --  *      br0     172.17.2.0/24        172.17.2.0/24
Chain LOCALSRV (0 references)
Chain VSERVER (1 references)
    0     0 DNAT       udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:55115 to:172.17.2.3:55115
[COLOR="Red"]    1    60[/COLOR] DNAT       tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:55115 to:172.17.2.3:55115
 7784  578K VUPNP      all  --  *      *       0.0.0.0/0            0.0.0.0/0
Chain VUPNP (1 references)
admin@(none):/tmp/home/root# iptables  -L -v -n
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
 1175 59728 DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0            state INVALID
 169K   25M ACCEPT     all  --  *      *       0.0.0.0/0            0.0.0.0/0            state RELATED,ESTABLISHED
 1113  202K ACCEPT     all  --  lo     *       0.0.0.0/0            0.0.0.0/0            state NEW
 365K  185M ACCEPT     all  --  br0    *       0.0.0.0/0            0.0.0.0/0            state NEW
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp spt:67 dpt:68
 7382  557K DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0
Chain FORWARD (policy ACCEPT 87 packets, 4644 bytes)
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            172.17.2.3           udp dpt:55115
[COLOR="red"]    2   120[/COLOR] ACCEPT     tcp  --  *      *       0.0.0.0/0            172.17.2.3           tcp dpt:55115
  12M 6521M ACCEPT     all  --  *      *       0.0.0.0/0            0.0.0.0/0            state RELATED,ESTABLISHED
    0     0 DROP       all  --  !br0   eth0    0.0.0.0/0            0.0.0.0/0
 7426  395K DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0            state INVALID
  164 12805 ACCEPT     all  --  br0    br0     0.0.0.0/0            0.0.0.0/0
    0     0 DROP       icmp --  eth0   *       0.0.0.0/0            0.0.0.0/0
  325 16612 ACCEPT     all  --  *      *       0.0.0.0/0            0.0.0.0/0            ctstate DNAT
Chain OUTPUT (policy ACCEPT 275 packets, 33362 bytes)
Chain FUPNP (0 references)
Chain PControls (0 references)
    0     0 ACCEPT     all  --  *      *       0.0.0.0/0            0.0.0.0/0
Chain logaccept (0 references)
    0     0 LOG        all  --  *      *       0.0.0.0/0            0.0.0.0/0            state NEW LOG flags 7 level 4 prefix "ACCEP        T "
Chain logdrop (0 references)
    0     0 LOG        all  --  *      *       0.0.0.0/0            0.0.0.0/0            state NEW LOG flags 7 level 4 prefix "DROP        "
    0     0 DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0
