Stefan1200
I use an Asus RT-N66U router with a cable modem set in bridge mode. Asuswrt is showing my correct external IPv4 address. Currently using Merlin Firmware 374.41, but I had this problem also with 374.40.
After some tests with Bit Torrent (using port 5321) and FTP services I found out, that port forwarding don't work. Even if I disable my local firewall on my PC and the firewall on the Asus router I don't get a connection to my Windows 7 PC, ip: 192.168.1.240. PC is connected using LAN cable. Tried this with the connection tester of the Bit Torrent client and using a FTP client on my smartphone while using UMTS (not wlan). All tests failed, connection not possible.
What's the problem? Some ideas?
Here some information of the router protocols:
Connections (while downloading a torrent)
Port Forwarding
Routing Table
udp 81.162.56.98:6881 192.168.1.240:5321 UNREPLIED
udp 192.168.1.240:5321 37.113.185.122:6881 UNREPLIED
udp 192.168.1.240:5321 95.72.245.8:11888 UNREPLIED
udp 31.15.239.25:3940 192.168.1.240:5321 UNREPLIED
udp 192.168.1.240:5321 46.63.135.195:54550 UNREPLIED
udp 95.72.21.8:11888 192.168.1.240:5321 UNREPLIED
udp 192.168.1.240:5321 37.110.49.145:56881 UNREPLIED
udp 192.168.1.240:5321 86.100.222.204:10498 UNREPLIED
udp 192.168.1.240:5321 178.202.82.100:6241 UNREPLIED
Port Forwarding
Destination Proto. Port range Redirect to Local port Chain
ALL TCP 5200:5399 192.168.1.240 5200:5399 VSERVER
ALL UDP 5200:5399 192.168.1.240 5200:5399 VSERVER
Routing Table
Destination Gateway Genmask Flags Metric Ref Use Iface
31.16.215.254 * 255.255.255.255 UH 0 0 0 WAN
192.168.1.0 * 255.255.255.0 U 0 0 0 LAN
31.16.208.0 * 255.255.248.0 U 0 0 0 WAN
default 31.16.215.254 0.0.0.0 UG 0 0 0 WAN
