Potential issue on NFS server, RT-AC68U
matthew_eli
Hi all,
I encountered a problem I've not faced before with RT-N66U about the built-in NFS server; using NFS server in RT-AC68U and setting it like I had in RT-N66U, results in no NFS server at the router boot. Let me explain better; I use NFS for mounting the Hard Disk on USB and then reading it by my WDTV Live over ethernet. When I had Rt-N66U I set the NFS as in the following image:
and all works flawlessly, since from the router boot. Instead, with my new RT-AC68U, .38_1 firmware by Merlin, using the same settings, I need to manually turn off and on the NFS exports or simply changing any settings of it for having the export mount seen by my WDTV. Most probably using the WDTV is not the best way to debug if the NFS exports are working normally and thus I would ask you a way for testing it effectively.
I enclose in the following what log reports for the NFS:
When I change the settings and the service starts correctly (at least it is accessible by WDTV):
Jan 13 09:20:03 statd[2339]: Version 1.1.6 Starting
Jan 13 09:20:03 statd[2339]: statd running as root. chown /var/lib/nfs/sm to choose different user
Jan 13 09:20:03 kernel: svc: failed to register lockdv1 RPC service (errno 97).
When the service starts at boot (there are 2 differents date, but it's for the NTP read, it happens all in few seconds):
Jan  1 01:00:43 kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan  1 01:00:43 kernel: Installing knfsd (copyright (C) 1996 [email protected]).
Jan  1 01:00:44 statd[1202]: statd running as root. chown /var/lib/nfs/sm to choose different user
Jan  1 01:00:44 kernel: svc: failed to register lockdv1 RPC service (errno 97).
Jan 12 16:40:59 mountd[1218]: Caught signal 15, un-registering and exiting.
Jan 12 16:40:59 kernel: nfsd: last server has exited, flushing export cache
Jan 12 16:41:54 kernel: svc: failed to register nfsdv3 RPC service (errno 111).
Jan 12 16:41:54 kernel: nfsd: last server has exited, flushing export cache
Jan 12 16:41:54 nfsd[1531]: nfssvc: writing fds to kernel failed: errno 111 (Connection refused)
Jan 12 16:41:54 nfsd[1531]: nfssvc: Address already in use
Jan 12 16:41:55 mountd[1541]: unable to register (mountd, 1, udp).
Could you help me in figuring this problem out?
No one facing thw same problem? Do you know a tool for debugging NFS on Windows 8.1?
Try to be a little more patient and let people who can answer either wake up or finish work first... ;)
You're right. I'll be...:D
Ty. Try to give at least 24 hrs before you bump a thread. :)
I have the same issue on the AC68U - on the N66U it works like a charm! :rolleyes:
With kind regards
Joe :cool:
Log of the AC68U for NFS enable:
Feb 15 22:07:33 portmap[1376]: cannot bind tcp: Address already in use
Feb 15 22:07:33 statd[1378]: Version 1.1.6 Starting
Feb 15 22:07:33 statd[1378]: unable to register (statd, 1, udp).
Feb 15 22:07:35 crond[551]: time disparity of 1644307 minutes detected
Feb 15 22:08:24 rc_service: httpd 548:notify_rc restart_nasapps
Feb 15 22:08:24 rc_service: waitting "restart_nasapps" via ...
Feb 15 22:08:27 kernel: svc: failed to register nfsdv3 RPC service (errno 111).
Feb 15 22:08:27 kernel: nfsd: last server has exited, flushing export cache
Feb 15 22:08:27 nfsd[1380]: nfssvc: writing fds to kernel failed: errno 111 (Connection refused)
Feb 15 22:08:39 rc_service: skip the event: restart_nasapps.
Feb 15 22:09:09 rc_service: httpd 548:notify_rc restart_nasapps
Feb 15 22:09:09 rc_service: waitting "restart_nasapps" via ...
Feb 15 22:09:24 rc_service: skip the event: restart_nasapps.
Feb 15 22:09:27 kernel: svc: failed to register nfsdv3 RPC service (errno 111).
Feb 15 22:09:27 kernel: nfsd: last server has exited, flushing export cache
Feb 15 22:09:27 nfsd[1380]: nfssvc: writing fds to kernel failed: errno 111 (Connection refused)
Feb 15 22:10:27 nfsd[1380]: nfssvc: Address already in use
Feb 15 22:10:27 kernel: nfsd: last server has exited, flushing export cache
Feb 15 22:10:27 mountd[1412]: unable to register (mountd, 1, udp).
Anyone get it working. I am still not able to get it work with even with latest firmware 376.47
Recent test on RT-AC68U show that the issue still exists in the firmware (Merlin build 376.48_1) - see log below.
Did anyone try to get NFS working with Entware/Optware?
Would need some tweaking to get firmware round the build in NFS and portmapper... :rolleyes:
With kind regards
Joe :cool:
PS.: The topic was also handled in this thread - but no solution so far...
Nov  8 21:35:47 kernel: RPC: Registered udp transport module.
Nov  8 21:35:47 kernel: RPC: Registered tcp transport module.
Nov  8 21:35:47 kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Nov  8 21:35:47 kernel: Installing knfsd (copyright (C) 1996 [email protected]).
Nov  8 21:35:47 statd[1234]: Version 1.1.6 Starting
Nov  8 21:35:47 statd[1234]: statd running as root. chown /var/lib/nfs/sm to choose different user
Nov  8 21:35:47 kernel: svc: failed to register lockdv1 RPC service (errno 97).
Nov  8 21:35:50 rc_service: hotplug 582:notify_rc restart_nasapps
Nov  8 21:35:50 iTunes: daemon is stopped
Nov  8 21:35:50 FTP Server: daemon is stopped
Nov  8 21:35:52 Samba Server: smb daemon is stopped
Nov  8 21:35:52 kernel: gro disabled
Nov  8 21:35:52 mountd[1240]: Caught signal 15, un-registering and exiting.
Nov  8 21:35:52 kernel: nfsd: last server has exited, flushing export cache
Nov  8 21:35:52 statd[1234]: Caught signal 15, un-registering and exiting.
Nov  8 21:35:52 Timemachine: daemon is stopped
Nov  8 21:35:52 kernel: gro enabled with interval 2
Nov  8 21:35:53 Samba Server: daemon is started
Nov  8 21:35:53 portmap[1307]: cannot bind tcp: Address already in use
Nov  8 21:35:53 statd[1309]: Version 1.1.6 Starting
Nov  8 21:35:53 statd[1309]: unable to register (statd, 1, udp).
