Soylent
I'm trying to find some research about Wi-Fi penetration through poured concrete walls compared to hollow concrete block walls.
My theory with hollow blocks is the Wi-Fi signal will penetrate the inner layer of the block, diffuse and bounce around inside the hollow area, thus weakening it too much to penetrate the outer layer.
However, poured concrete walls are solid. It's a single barrier that a sufficiently powerful signal will still penetrate. It may be limited to 2.4ghz, but it should work.
Assuming I'm correct that hollow blocks are practically impenetrable, is there any way to mitigate the effect of hollow concrete blocks? Like filling them up with concrete?
