@kuchkovsky has a patch for the current version here, it should work with the new one too? https://github.com/kuchkovsky/asusw...v-file#7-traffic-monitor-table-patch-kbs--mbsWill there be an option for Mbps in the new TM?
No. I rewrote the whole page nearly from scratch, and it's no longer relying on the old Tomato code that this was patching.@kuchkovsky has a patch for the current version here, it should work with the new one too? https://github.com/kuchkovsky/asusw...v-file#7-traffic-monitor-table-patch-kbs--mbs
Good thing it is not too similar to GLiNET BE3600... flatttery and all that ...New model that will be added with 3006.102.6:
Beside being marketed as a travel router, Asus strongly recommended supporting that model because they see it as an affordable entry level Wifi 7 device....
Interesting router. For those interested in learning more about the RT-BE58 GO see here:New model that will be added with 3006.102.6:
Beside being marketed as a travel router, Asus strongly recommended supporting that model because they see it as an affordable entry level Wifi 7 device. We'll see how popular it will be over time. I believe the current availability ETA is somewhere at the end of October according to some resellers (I don't have any official availability date from Asus, sorry).
BTW, that model does support Wireless Client mode (i.e. the WAN interface can be connected to a public Wifi network, for example).
www.asus.com
I'm curious, why are the ZenWiFi BE models not supported? The BQ16 and BT10 have pretty good hardware, a nice non-spider design, and they're not niche products like travel routers.
www.snbforums.com
That was also my initial thought, but Asus' marketing has bigger plans than just have it be a niche traveling product. I reckon the price will determine everything. For a small apartment, a sub-$200 WIfi 7 router might be interesting. Time will tell. Worst case scenario, it goes EOL sooner than the rest.I personally don't think this model will be very popular. It's a niche product similar to GL.iNet travel routers. They are good for few local devices at best. Faster than GbE ports and Wi-Fi 6/7 are totally irrelevant features for most common use cases.
I would consider replacing my GL-inet with this device if it could solve the sign on issues when trying to connect to some hotel's Wifi. Sometimes I can but at one hotel I stay at frequently it seems impossible.I have first hand experience with similar product. WISP is useful for eventually boosting hotel Wi-Fi. I've done it few times and gave up. It also makes the router single-band on the client side. Travel routers have common login issues to public Wi-Fi with access portals. Hopefully ASUS offers some acceptable workaround. Most hotels have 2.4GHz Wi-Fi, some offer Ethernet. Both options are limited throughput. I haven't seen anything better than FE speeds. Many places around the world limit VPN use as well. When VPN is working I personally run it on a client device without extra complications.
For small apartments - perhaps usable, but in a place like this usually live 1-2 people. They most likely don't need multi-Gigagit ISP line and with single 2.5GbE port throughput >Gigabit can be reached as aggregate only. This is a dual-band router, wireless in close to ideal conditions about Gigabit. The rest through the single LAN port, eventually. Extra switch may be needed in home environment. Bumping the specs of such device doesn't make sense. Both 2.5GbE WAN and Wi-Fi 7 in reality bring no benefits. Currently available RT-AX57 Go does exactly the same thing for under $100 price.
I seriously doubt that this will be able to come anywhere close or in any way compete with GL.iNET in that regard. Just think of the amount of options available in GL.iNET like MAC clonning, camouflage mode and TTL changing and you'll realise that this Asus is unlikely to have any chance here. I would, however, be delighted to be proven wrong.I would consider replacing my GL-inet with this device if it could solve the sign on issues when trying to connect to some hotel's Wifi. Sometimes I can but at one hotel I stay at frequently it seems impossible.
FYI My Gl-inet unit will connect to WiFI on either 2.4 Ghz or 5 Ghz and rebroadcast the Internet on both bands. It also runs a WG VPN client with the equivalent of a VPN director allowing me to connect phones and tablets to a VPN and my Roku for Netflix to the WAN. Great features, but only if you can connect to the WiFi source.
Well .. RMerlin got one for testing so maybe it’ll become a Merlin FW candidate, then anything is possible … but yes the GLiNet devices benefit from being based on OpenWRT so apart from the native features, Apps and Addon libraries are plentiful.I seriously doubt that this will be able to come anywhere close or in any way compete with GL.iNET in that regard. Just think of the amount of options available in GL.iNET like MAC clonning, camouflage mode and TTL changing and you'll realise that this Asus is unlikely to have any chance here. I would, however, be delighted to be proven wrong.
Does this Asus support wifi eap? Gl-inet does.I seriously doubt that this will be able to come anywhere close or in any way compete with GL.iNET in that regard. Just think of the amount of options available in GL.iNET like MAC clonning, camouflage mode and TTL changing and you'll realise that this Asus is unlikely to have any chance here. I would, however, be delighted to be proven wrong.
Don't know about this new one but I have the RT-AX57 Go and it is a total cripple when compared to the GL.iNET products and has been confined to a drawer collecting dust for some time now.Does this Asus support wifi eap? Gl-inet does.
VPN support is a core feature for travel routers, yet it appears thr Asus will not be great at that either.
Oh just use it as a mesh node ! It is on the ASUS famous GNP and VLAN lists … or just send it to me I’ll adopt it and give it the life it deserves ..Don't know about this new one but I have the RT-AX57 Go and it is a total cripple when compared to the GL.iNET products and has been confined to a drawer collecting dust for some time now.
Oh just use it as a mesh node ! It is on the ASUS famous GNP and VLAN lists … or just send it to me I’ll adopt it and give it the life it deserves ..![]()
Let me think about this for a nanosecond… ah … nope.Would seriously be more than happy to do a straight swap with your Beryl AX.![]()
We use essential cookies to make this site work, and optional cookies to enhance your experience.
