Proper way to Factory Default a router?
  • Thread starter Thread starter nikr
  • Start date Start date
N
nikr
Guest
I am brand new AX86U. And I have been having issues with guest network. I've another thread for that issue. Anyways, one last time I want to Factory default router and try to setup it up again, in hope that it might work this time. I usually reset to default from UI. Is it good enough? Is there a proper way to default a router, which ensures that no traces of previous settings stays around.
Is reset from UI, Holding down reset button and holding down WPS button during boot all do the same thing? Is one better then other. Anything else I should be doing before or after reset in order for reset to be effective?
They should all to the same thing. Using the GUI method has an additional option to "initialise" the jffs partition which may help.
  1. Enable ssh in router with port as 22 (RT-AX88U/AX-86U or current Broadcom AX based routers for example)
  2. Launch Windows Powershell as Admin
  3. login to router with below command
  4. ssh admin@192.168.50.1 (Admin or any username and IP of your router)
  5. Enter Password
  6. Pass this command hnd-erase nvram and press Enter
  7. Immediately turn off router from wall's power socket, Unplug power cable or turn on/off switch. Then turn it on again.
  8. Router should be properly reset.
Merlin suggested to reboot router by physically cutting power to it and not through GUI. There is a chance the old NVRAM values in memory might again be written back to router nullifying your reset efforts.
  5. Enter Password
Will the above process work with an AiMesh system? I have 3 XT8 units (router and 2 nodes). Would this clear each unit?
Yes. Even I have 3 RT-AX88U and I first remove the nodes from GUI. This causes them to factory reset. Then I do the above steps to reset only on main router. I don't reset nodes this way.
