QOS bandwidth limitation per device below 1Mb/s
ben0a
Hi all,
I'm using 380.65 merlin version on ARM. I did look around but can not find any explanation on how I can limit upload bandwidth below the minimum on the GUI of 1Mb/s.
I'm on ADSL and have 10Mbs/s down and 1Mbs/s up. Most of my devices are apple devices and use iCloud extensively. do you know way via cli to limit the upload speed of the devices in order for them to not saturate the upload but still sync?
I can put 0.7 Mb/s in the GUI on the device but based on my tests it does not seem to do anything.
ben0a
You can't set it in kilobits?
When I use a decimal (like .5 or .7) to indicate a portion of a Mb/s bw it seems to work fine for me when I test. I've bee using it for a while now. .1 Mb is as granular as you can specify which seems quite reasonable.
