R7800 entware installation opkg update fails. Wrong download address?
pikolo
Greetings,
I am trying to install entware in my R7800 router, following the instructions in Voxel's readme.
I am using Voxel's firmware R7800-V1.0.2.74.1SF
I used a usb-stick in NTFS format.
Untared the file "entware-cortex-a15-3x-initial-generic.tar.gz"
Tried the command "opkg update" and I receive the error message that it cannot download the attitude_management/12.09_RC1 ipq806x package
I tried to manually find the package and install it, but the download address that the command "opkg update" is using is not valid.
I would be grateful for any help.
Just a guess, but NTFS is not supported.
I also think you may need a swap file too.
First, @L&LD is right. NTFS is strongly not recommended for use with Entware. Please use ext4 - native Linux partition:
mkfs.ext4 -L optware -O ^metadata_csum /dev/sda1
above is an example of the command how to format your disk to ext4 for R7800
Second, use the full path for opkg:
/opt/bin/opkg update
/opt/bin/opkg upgrade
By default "/opt/bin" is not included into PATH so you are using /bin/opkg and the last is "opkg" used for internal needs in firmware, not for Entware...
Voxel.
Hello and thanks for your replies.
Using the full path as Voxel suggested solved the problem. So now I should reformat the drive as ext4 and repeat the procedure......
Another problem I have is that the "Reboot" command from the router's webpage kills the internet connection upon reboot. The router cannot update its DHCP settings, everything is zero. If I turn OFF and ON the router's power, then it is OK.....
