LeKeiser
Hello everyone,
Well, I get home, I say "Alexa, what time is it ?" and I see the red circle on the device, "I cannot connect to the Internet"
So I check what WiFi is available, and gone is my 5GHz SSID. There is only the 2.4 SSID available. I log on the router, and everything seems ok. But still, no 5GHz SSID
My only option is to reboot the router. That's what I do. But it takes time to fully reboot. More time than usual. But it does reboot. And the 5Ghz SSID comes back.
My questions are :
_ what do you think cause that ? It's not the first time this happens. But the last time happened 4 or 5 months ago. Is my loving router getting too old ?
_ was there something to do before rebooting the router ? Should I have checked a log or something ? If so, where ?
_ I really need my Internet connection. If my loving router dies on me, which one should I buy fast ? I have about 25 devices connected, ethernet and WiFi.
Oh, I'm using Mr @Voxel latest firmware and Mr @kamoj latest add-on. Beside this WiFi problem, my loving R7800 is working like a charm. I would prefer to keep it that way, for many years still
Thanx a lot for your returns
Cheers
My questions are :
Cheers
