[R7800] wireguard-go doesn't get working
Tume
Hi! I tried to get wireguard-go working with Voxel FW.
I have Mullvad VPN. I created .conf file by their site and it looks like this:
[Interface]
PrivateKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Address = 10.66.131.5/32,fc00:bbbb:bbbb:bb01::3:8304/128
DNS = 193.138.218.74
[Peer]
PublicKey = YYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY
AllowedIPs = 0.0.0.0/0,::0/0
Endpoint = 185.204.1.203:3024
First problem is, when I try to set that .conf file to my wg0 interface, it says:
root@R7800:/$ wg syncconf wg0 wg.conf
Line unrecognized: `Address=10.66.131.5/32,fc00:bbbb:bbbb:bb01::3:8304/128'
Configuration parsing error
Okay, that's fine. Let's remove that line.
Line unrecognized: `DNS=193.138.218.74'
Let's remove that line too. Then it works. now command wg show us:
root@R7800:/$ wg
interface: wg0
  public key: ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
  private key: (hidden)
  listening port: 51907
peer: ny9u5anjMGsoe2Yrf3wqZMvSifNtTknVMz3KfblWpi0=
  endpoint: 185.204.1.203:3024
  allowed ips: 0.0.0.0/0, ::/0
ip link show us:
root@R7800:/$ ip link show wg0
34: wg0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1420 qdisc pfifo_fast state UNKNOWN mode DEFAULT qlen 500
    link/none
OK. Then I add ip address to wg0 interface
 ip address show wg0
34: wg0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1420 qdisc pfifo_fast state UNKNOWN qlen 500
    link/none
    inet 10.66.131.5/32 scope global wg0
Then I just give command: ip link set up dev wg0
It doesn't give any response after that. It just doesn't affect at all and I don't have any idea why?
- Tume
Very brief.
This add-on is not tested yet and is published for testing by kamoj. He did not test this yet. So there is no readme for this. I cannot test myself unfortunately because of self-isolation.
If you want to test yourself with your provider you should:
(1) Install both packages
(2) Prepare /etc/wireguard.conf according to this instruction (end of my very first post, WireGuard client).
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-38hf.61402/
(3) Enable /etc/init.d/wg-client
/etc/init.d/wg-client enable
nvram set wg-client=1
nvram commit
(4) Run it manually or by reboot of your router
/etc/init.d/wg-client start
(5) Check its log /var/log/wireguard-client.log in the case of problems.
P.S. Do not expect super fast speed from Wireguard-Go...
Voxel.
Hi Voxel!
Thank you for helping me!
INFO: (wg0) 2020/04/09 12:42:48 Starting wireguard-go version 0.0.20200320
RTNETLINK answers: File exists
RTNETLINK answers: No such process
Restart firewall to apply iptables rules for WireGuard client.
Generating Rules...
Done!
Starting Firewall...
Done!
Still https://am.i.mullvad.net/ say You are not connected to Mullvad. I'm out of ideas again.
/etc/wireguard.conf looks like this:
EndPoint="185.204.1.203"
LocalIP="10.66.131.5"
PrivateKey="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX="
PublicKey="YYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY="
Port="3024"
I also set echo "nameserver 193.138.218.74" >> /etc/resolv.conf as their conf file said. WG just doesn't work.
RTNETLINK answers: File exists RTNETLINK answers: File exists RTNETLINK answers: No such process
There should not be such messages. It is bad. As I said I did not test it. Only very initial tests long time ago by kamoj.
Try to disable wireguard in nvram, reboot your router, enter by telnet/ssh and run
manually. To check that it is OK. After that result of "route" command. And your log file.
And to check that you are connected or not:
ping 8.8.8.8
traceroute 8.8.8.8
Voxel.
