Reverse dns lookup?
nlehrer54
Hi.
I have an rt-1900p on current release of merlin. Is there any way to enable reverse resolution for ip nums in syslog?
Thank you.
RMerlin
Asuswrt-Merlin dev
If you are referring to iptables logs, then no, as that would be a huge performance drag. Iptables only logs IP addresses.
nlehrer54
Thanks. I was looking at the drops. It is a lot of work doing it manually, but i understand about the perf drag.
Do you know of any apps that can scan a saved log and look up the ip nums?
RMerlin
Asuswrt-Merlin dev
