Root user?
Cumulonimbus
Root user / Sundtek Install?
Hello,
will try install sundtek tv-stick on the Firmware. But i need an Root Account.
admin@RT-AC66U:/tmp# sh sundtek_netinst.sh
Busybox installation
In order to install this driver please run it as root
eg. $ sudo sundtek_netinst.sh
But sudo not on the Router.
How can i become a root acount on the router?
admin is the firmware superuser (UID1). If a script complains about it, it needs to be changed not to assume that UID1 is named "root".
I'm curious: why would one install a tv-stick on the ac66u? Am I missing some brilliant use for it?(?)
This Stick has inbuild Network-Support. You can stream and control the TV-Signal to all Devices in the Network, like TV-Software that uses BDA-Devices.
sundtek dvb-c problem
Hello,
Who can help me with installation from my sundtek DVB-C on my Asus RT-N66U with the firmware from Merlin.
What I done to install the DVB-C stick on my asus router:
I Login in my asus router with ssh.
> wget http://www.sundtek.de/media/sundtek_netinst.sh
> chmod 755 sundtek_netinst.sh
> ./sundtek_netinst.sh -admin
> mediaclient --enablenetwork=on &
Now I have a remote connection with my DVB-C stick, and can watch TV over te LAN :)
But I have problem :(
When I exit the ssh connection with my asus router, the DVB-C stick stops to work, no tv any more over the lan.
I also try the first steps with this command:
> /tmp/opt/bin/mediasrv -d
but this will not work.
it will only works when I do all first steps, and not exit the ssh connection.
Can someone help, to get this DVB-C stick running on my Asus router
Hello,
Hello Cumulonimbus.
Did you fix your problem with the sundtek installation on your asus router?
Can you help me?
Thanks,
Regards,
Michel
