Router Advice
Dazman
Thoughts on ASUS ROG Gaming Wireless AX11000 Tri-Band Wi-Fi 6 Gaming Router (ROG GT-AX11000) vs the AX5700?
Without knowing anything about your environment, ISP speeds, LAN needs/layout, and the specific model numbers (AX5700 doesn't mean anything), there is little to share here.
What do you have? What do you expect with a new router? Again, be specific.
I have the ASUS Wireless AX5700 Dual-Band Wi-Fi 6 Gaming Router (RT-AX86U)
and it stopped working after 5 years. When I get home, in another week, I’ll try doing a factory reset because my wife said the red light is on and I unbridged the service provider’s modem and using that for now.
Currently, a wired computer, PS5 and security cameras. Multiple phones, iPads, doorbell, thermostat, smoke alarms and laptops.
Looking for consistent speeds as both are on sale. $250 for the AX5700 and the other router is $319 Canadian.
If you really need a new router (see the following link to try to get your router back), I wouldn't be looking at either of those models. The GT-AX6000 is the best bang for the buck today. And when on sale, it may be found for less than the prices you indicate.
BTW, the RT-AX86U isn't a five-year-old model (yet).
Your additional info still isn't enough info.
Unfortunately, this post was a last minute decision as I’m not home and flying at the moment with limited cell coverage.
And that mere $30 price difference over the GT-AX11000, per the information you've provided so far, is well worth it.
The RT-AX86U isn't worth buying today. It won't receive 3.0.0.6.xxx firmware (later this year), and it is outclassed by the GT-AX6000 on many levels.
