rp-ax56 in aimesh mode with rt-ax82u setup 160mz question
accat13
First time post after reading enough to be slightly dangerous to my network. The rt-ax82u has 386.5_2-gnuton0 firmware and the rp-ax56 is latest stock firmware.The aimesh network seems to be working ok . My question is with the wireless setup do I enable 160mhz on 5g or leave it disabled as the rp-ax56 does not support 160mhz.
Thank you
Do you have any 160MHz capable devices?
Do you want maximum 5GHz Wi-Fi stability?
Devices yes phone and tablet and yes to stability. My assumption would be that the devices would connect on the rt-ax82u for stabilty but not ont the rp-ax56
Phone and tabled don't need 160MHz. It uses DFS range, any detected radar transmission will disrupt your 5GHz Wi-Fi. You have some choices to make.
