You will likely be limited to the number of guest WIFI you can push to the extender. I believe that will be the only limitation as the extender does have 160 MHz on the 5 GHz. But, do not expect any more bandwidth through the extender than what you have now.What limitations does the RP-AX58 Extender have when set up with AiMesh on a RT-AX86 pro with Guest Net Pro? Currently using on a RT-AX86 (not pro). Don't have the space for a standalone router to use as an AiMesh node.
Welcome To SNBForums
