Two DNS requests to amazonaws every 30 seconds since installing AIMesh
Does your router have a domain? Does bifrost.home.arpa (or whatever your domain is) work? Is the lack of dots a factor?
I had same thought you did after my last post. My local domain is indeed .home.arpa, and trying bifrost.home.arpa:8443 via browser doesn't connect at all.
Might not be a security issue after all. For some reason the router fails to properly parse it to extract the port when using that name versus when using the original router name:
Jul 16 17:03:46 debug: host_name: gtaxe16000:8443 - host_name_temp: gtaxe16000
Jul 16 17:04:09 debug: host_name: bifrost:8443 - host_name_temp: bifrost:8443
The router calls ParseIPv4OrIPv6() on your hostname, and it fails to detect "bifrost" as being a hostname and considers it to be an IP.
The simplest workaround on your end is within your local host file, add a FQDN for it. I.e.:
192.168.50.1 bifrost bifrost.mylonely.lan
Then if you use https://byfrost.mylonely.lan:8443 it will properly be detected as a hostname, and get correctly parsed.
I can probably protect ParseIPv4OrIPv6() by checking first if the string is devoid of any dot and bracket (an IPv6 would be enclosed in brackets), in which case I would process it as a hostname. That wouldn't be 100% fool proof, but a proper fix would probably require the lengthy ParseIPv4OrIPv6() function to be reworked - not something I'm really keen on attacking myself.
So I just tried that, and it fails certificate check and drops down to port 80. So, yeah, looks like I'll have to explicitly add bifrost.home.arpa to my certificate to make that work. And since I had to remake it recently and the process is fresh in my mind, and I'm quite curious if this'll actually *work* (meaning system status page doesn't break), let me go ahead and try that. For the science.
Does it receive the :8443 and consider the colon to be part of an IPv6 address?
No, because it deals fine with gtaxe16000:8443.
That is a browser issue. With a regular browser (Chrome or Firefox), you can tell it to accept the certificate anyway, and it should not try to switch you to a different port.
Sigh. Merlin, if you're taking requests... could you just make the router do a service restart_httpd after importing a new certificate? I mean, couldn't Asus just assume that would be obviously necessary part of the process? Either you have to ssh and run that manually or wait like half an hour for it to restart on its own, otherwise it keeps serving up the old cert. Took me like 20 minutes to figure out why it wasn't taking. The whole importing cert process is painful enough for most people without having that idiocy confusing the hell out of people. Bet it would reduce complaints/questions on that topic a lot.
Anyway. So, yes, if you have bifrost.home.arpa in the certificate AND you pull it up via bifrost.home.arpa:8443, it does parse correctly, and status page works. Still can't do bifrost:8443 tho.
It does that, but only after you log out, to limit disruptions.
        else if (!strcmp(script, "prepare_cert")) {
                int r;
                r = prepare_cert_in_etc();
                if (r > 0) {
                        /* Load new certification after the current session logout. */
                        nvram_set("httpds_reload_cert", "2");
#if defined(RTCONFIG_IPV6)
                        if (ipv6_enabled() && nvram_match("misc_http_x", "1")) {
                                nvram_set("httpds6_reload_cert", "2");
#endif
It probably also does it this way so it can validate the certificate before reloading it.
This should take care of most cases of incorrectly detected IPs.
I had a look at potentially rewriting ParseIPv4OrIPv6(), but too many chances of something else breaking along the way.
Did you figure out why gtaxe16000:8443 was OK but not bifrost:8443? Was it the digits before the colon?
No idea. The ParseIPv4OrIPv6() is so long and complicated that I didn't bother trying to understand where it failed. I doubt that was it tho, because I use "stargate" on my primary router.
Good to know about logging out triggering httpd restart. I was shutting down all tabs browsing to my router, but didn't think to explicitly log out. And thanks for taking care of this weird bifrost parsing issue.
Now to return to the OP topic - do you have any insight on what awsiot actually does? Like what features it enables/is used for? It seems like it was engaged in a whole lot of communication for a feature that I wasn't even using, or at least whose absence I am not missing. I was able to resolve it by declining Asus privacy permissions because I'm not using any of the features that enables, but seems to me other users who do want those features won't have that option, and there could be at least some efficiency gains (not to mention privacy/security gains) in making the run of that service conditional on... well, whatever it's actually needed for actually being used.
Given the aws link, I'm *guessing* it's just for Alexa controlling IoT devices. I'd think plenty of people who want *a* feature that requires Asus privacy permissions aren't necessarily running Alexa and all that awsiot traffic isn't necessary for them.
It's not just for Alexa. I know that it's related to the Tencent game accelerator feature among other things, but I don't know anything more - I've never looked into it. I think it's also tied to a future cloud-based router management plan that they seem to have.
I found that every time a router LAN port flaps (e.g. a printer sleeping or waking up), the router initiates a connection to aae-pns001-1.asuscomm.com defined in nvram aae_pnsinfo.
Jul 18 07:12:51 kernel: eth4 (Int switch port: 3) (Logical Port: 3) (phyId: 4) Link DOWN.
Jul 18 07:12:51 kernel: br0: port 4(eth4) entered disabled state
Jul 18 07:12:53 kernel: eth4 (Int switch port: 3) (Logical Port: 3) (phyId: 4) Link Up at 100 mbps full duplex
Jul 18 07:12:53 kernel: br0: port 4(eth4) entered blocking state
Jul 18 07:12:53 kernel: br0: port 4(eth4) entered forwarding state
Jul 18 07:13:12 kernel: OUTPUT IN= OUT=eth0 SRC=x.x.x.x DST=15.197.211.227 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=56680 DF PROTO=TCP SPT=53862 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
Jul 18 07:13:12 kernel: OUTPUT IN= OUT=eth0 SRC=x.x.x.x DST=15.197.211.227 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=46734 DF PROTO=TCP SPT=53864 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
Jul 18 07:13:13 kernel: OUTPUT IN= OUT=eth0 SRC=x.x.x.x DST=15.197.211.227 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=25649 DF PROTO=TCP SPT=53866 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
Jul 18 07:13:13 kernel: OUTPUT IN= OUT=eth0 SRC=x.x.x.x DST=15.197.211.227 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=34518 DF PROTO=TCP SPT=53868 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
Jul 18 07:17:55 kernel: eth4 (Int switch port: 3) (Logical Port: 3) (phyId: 4) Link DOWN.
Jul 18 07:17:55 kernel: br0: port 4(eth4) entered disabled state
Jul 18 07:17:56 kernel: OUTPUT IN= OUT=eth0 SRC=x.x.x.x DST=15.197.211.227 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=58703 DF PROTO=TCP SPT=53870 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
Jul 18 07:17:57 kernel: eth4 (Int switch port: 3) (Logical Port: 3) (phyId: 4) Link Up at 10 mbps half duplex
Jul 18 07:17:57 kernel: br0: port 4(eth4) entered blocking state
Jul 18 07:17:57 kernel: br0: port 4(eth4) entered forwarding state
Jul 18 07:17:58 kernel: OUTPUT IN= OUT=eth0 SRC=x.x.x.x DST=15.197.211.227 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=13504 DF PROTO=TCP SPT=53872 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
Jul 18 07:17:58 kernel: OUTPUT IN= OUT=eth0 SRC=x.x.x.x DST=15.197.211.227 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=4710 DF PROTO=TCP SPT=53874 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
Jul 18 07:17:59 kernel: OUTPUT IN= OUT=eth0 SRC=x.x.x.x DST=15.197.211.227 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=58550 DF PROTO=TCP SPT=53878 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
Jul 18 07:17:59 kernel: OUTPUT IN= OUT=eth0 SRC=x.x.x.x DST=15.197.211.227 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=13388 DF PROTO=TCP SPT=53876 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
Jul 18 07:17:59 kernel: OUTPUT IN= OUT=eth0 SRC=x.x.x.x DST=15.197.211.227 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=40930 DF PROTO=TCP SPT=53882 DPT=443 WINDOW=64240 RES=0x00 SYN URGP=0
# nvram get aae_pnsinfo
# dig aae-pns001-1.asuscomm.com. +short
15.197.211.227
It seems there’s some connection between conn_diag and this aae/AWS stuff.
The connection is actually made by nt_center to the remote URL, with the connection details visible in /tmp/nc/pns_info.
I don’t know if I inadvertently enabled anything when testing Qwinn’s original question about awsiot, but I’m depressed that this has come to pass.
@ColinTaylor can you reproduce this by running strace on nt_center and flapping a LAN port? Or logging non-DNS packets in the OUTPUT chain?
iptables -A OUTPUT  -o eth0 -p tcp -m state --state NEW -m multiport ! --dports 53 -j LOG --log-prefix "OUTPUT " --log-ip-options
strace -fttp $(pidof nt_center) -o /tmp/nt_center.txt
Sorry, I'm not seeing anything.
I have no /tmp/nc/pns_info file and no DNS activity showing in the log. When flapping a LAN port strace does something with cfg_server and looks for /tmp/NTC_DEBUG and /tmp/IFTTT_ALEXA and if present writes to IFTTT_ALEXA.log.
# cat /tmp/IFTTT_ALEXA.log
[Notification_Center][receive_s:(140)]Received event [70004] that is no longer processed, ignore!
[Notification_Center][receive_s:(140)]Received event [70003] that is no longer processed, ignore!
# nvram show | grep ^aae
aae_area=aae-sgweb001-1.asuscomm.com
aae_awsiot_desc_updated=0
aae_disable_force=1
aae_enable=6
aae_portal=
aae_retry_cnt=0
aae_support=1
