Sean X Torres
RT-AC1200
Firmware Version: 3.0.0.4.380_9474
We had an issue this afternoon that took our Control room machine connection to the inventory server, down.
A restart seemed to fix the issue but I am unaware at the moment if they did a hard reset or if the router reset it's self.
This goes on for a bit...
Another interesting bit
Jul 9 20:07:43 rc_service: ntp 336:notify_rc restart_upnp
Jul 9 20:07:43 miniupnpd[335]: shutting down MiniUPnPd
Jul 9 20:07:43 miniupnpd[346]: version 1.9 started
Jul 9 20:07:43 miniupnpd[346]: HTTP listening on port 54695
Jul 9 20:07:43 miniupnpd[346]: Listening for NAT-PMP/PCP traffic on port 5351
Jul 9 20:07:44 kernel: DROP IN=vlan2 OUT= MAC=4c:ed:fb:d7:9a:84:b0:6e:bf:e4:af:e4:08:00:45:00:01:18 SRC=104.25.254.31 DST=192.168.50.53 LEN=280 TOS=0x00 PREC=0x00 TTL=52 ID=28677 DF PROTO=TCP SPT=443 DPT=58705 SEQ=2055662914 ACK=1124357327 WINDOW=511 RES=0x00 ACK PSH URGP=0
Jul 9 20:07:45 kernel: DROP IN=vlan2 OUT= MAC=4c:ed:fb:d7:9a:84:b0:6e:bf:e4:af:e4:08:00:45:00:00:56 SRC=52.72.41.54 DST=192.168.50.53 LEN=86 TOS=0x00 PREC=0x00 TTL=234 ID=41714 DF PROTO=TCP SPT=443 DPT=64750 SEQ=1558129737 ACK=3960486338 WINDOW=769 RES=0x00 ACK PSH URGP=0
Jul 9 20:07:45 kernel: DROP IN=vlan2 OUT= MAC=4c:ed:fb:d7:9a:84:b0:6e:bf:e4:af:e4:08:00:45:00:00:47 SRC=52.72.41.54 DST=192.168.50.53 LEN=71 TOS=0x00 PREC=0x00 TTL=234 ID=41715 DF PROTO=TCP SPT=443 DPT=64750 SEQ=1558129783 ACK=3960486338 WINDOW=769 RES=0x00 ACK PSH URGP=0
Jul 9 20:07:45 kernel: DROP IN=vlan2 OUT= MAC=4c:ed:fb:d7:9a:84:b0:6e:bf:e4:af:e4:08:00:45:00:03:61 SRC=173.194.67.125 DST=192.168.50.53 LEN=865 TOS=0x00 PREC=0x00 TTL=103 ID=31005 PROTO=TCP SPT=5222 DPT=55032 SEQ=3207109774 ACK=3380163460 WINDOW=1339 RES=0x00 ACK PSH URGP=0
Jul 9 20:10:36 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:d8:50:e6:3f:b5:7b:08:00:45:00:00:4e SRC=192.168.50.167 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=6231 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 20:10:36 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:d8:50:e6:3f:b5:7b:08:00:45:00:00:4e SRC=192.168.50.167 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=6232 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 20:11:37 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:d8:50:e6:3f:b5:7b:08:00:45:00:00:4e SRC=192.168.50.167 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=6233 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 20:11:38 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:d8:50:e6:3f:b5:7b:08:00:45:00:00:4e SRC=192.168.50.167 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=6234 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 20:11:39 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:d8:50:e6:3f:b5:7b:08:00:45:00:00:4e SRC=192.168.50.167 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=6235 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 20:11:45 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:38:60:77:39:44:e2:08:00:45:00:00:4e SRC=192.168.50.110 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=11394 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 20:11:45 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:38:60:77:39:44:e2:08:00:45:00:00:4e SRC=192.168.50.110 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=11395 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 20:11:46 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:38:60:77:39:44:e2:08:00:45:00:00:4e SRC=192.168.50.110 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=11396 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 20:11:49 miniupnpd[346]: upnp_event_recv: recv(): Connection reset by peer
Jul 9 01:28:56 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:d8:50:e6:3f:b5:7b:08:00:45:00:00:4e SRC=192.168.50.167 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=12044 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 01:28:56 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:d8:50:e6:3f:b5:7b:08:00:45:00:00:4e SRC=192.168.50.167 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=12045 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 01:29:58 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:d8:50:e6:3f:b5:7b:08:00:45:00:00:4e SRC=192.168.50.167 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=12046 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 01:29:59 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:d8:50:e6:3f:b5:7b:08:00:45:00:00:4e SRC=192.168.50.167 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=12047 PROTO=UDP SPT=137 DPT=137 LEN=58
Jul 9 01:29:59 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:d8:50:e6:3f:b5:7b:08:00:45:00:00:4e SRC=192.168.50.167 DST=192.168.50.255 LEN=78 TOS=0x00 PREC=0x00 TTL=128 ID=12048 PROTO=UDP SPT=137 DPT=137 LEN=58
Aug 1 00:00:16 syslogd started: BusyBox v1.17.4
Aug 1 00:00:16 kernel: klogd started: BusyBox v1.17.4 (2017-03-20 11:48:28 CST)
Aug 1 00:00:16 kernel: Linux version 2.6.36 (root@asus) (gcc version 4.6.3 (Buildroot 2012.11.1) ) #1 Mon Mar 20 11:52:54 CST 2017
Aug 1 00:00:16 kernel: The CPU feqenuce set to 580 MHz
Aug 1 00:00:16 kernel: Zone PFN ranges:
Aug 1 00:00:16 kernel: Normal 0x00000000 -> 0x00004000
Aug 1 00:00:16 kernel: Movable zone start PFN for each node
Aug 1 00:00:17 kernel: partion 3: ffffffff eb0000
Aug 1 00:00:17 kernel: partion 4: 17c640 d839c0
Aug 1 00:00:17 kernel: #add mtd partition#
Aug 1 00:00:17 kernel: Creating 7 MTD partitions on "raspi":
Aug 1 00:00:17 kernel: 0x000000000000-0x000000030000 : "Bootloader"
Aug 1 00:00:17 kernel: 0x000000030000-0x000000040000 : "nvram"
Aug 1 00:00:17 kernel: 0x000000040000-0x000000050000 : "Factory"
Aug 1 00:00:17 kernel: 0x000000050000-0x000000f00000 : "linux"
Aug 1 00:00:17 kernel: 0x00000017c640-0x000000f00000 : "rootfs"
Aug 1 00:00:17 kernel: 0x000000f00000-0x000001000000 : "jffs2"
Aug 1 00:00:17 kernel: 0x000000000000-0x000001000000 : "ALL"
Aug 1 00:00:39 kernel: DROP IN=vlan2 OUT= MAC=4c:ed:fb:d7:9a:84:b0:6e:bf:e4:af:e4:08:00:45:00:01:18 SRC=104.25.254.31 DST=192.168.50.53 LEN=280 TOS=0x00 PREC=0x00 TTL=52 ID=28675 DF PROTO=TCP SPT=443 DPT=58705 SEQ=2055662914 ACK=1124357327 WINDOW=511 RES=0x00 ACK PSH URGP=0
Aug 1 00:00:39 miniupnpd[335]: version 1.9 started
Aug 1 00:00:39 miniupnpd[335]: HTTP listening on port 34272
Aug 1 00:00:39 miniupnpd[335]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 1 00:00:39 kernel: DROP IN=vlan2 OUT= MAC=4c:ed:fb:d7:9a:84:b0:6e:bf:e4:af:e4:08:00:45:00:01:18 SRC=104.25.254.31 DST=192.168.50.53 LEN=280 TOS=0x00 PREC=0x00 TTL=52 ID=28676 DF PROTO=TCP SPT=443 DPT=58705 SEQ=2055662914 ACK=1124357327 WINDOW=511 RES=0x00 ACK PSH URGP=0
Aug 1 00:00:39 dhcp client: bound 192.168.50.53 via 192.168.50.1 during 86400 seconds.
Aug 1 00:00:39 kernel: DROP IN=vlan2 OUT= MAC=ff:ff:ff:ff:ff:ff:00:26:f2:b6:b7:77:08:00:45:00:01:48 SRC=0.0.0.0 DST=255.255.255.255 LEN=328 TOS=0x00 PREC=0x00 TTL=128 ID=27940 PROTO=UDP SPT=68 DPT=67 LEN=308
Aug 1 00:00:39 kernel: DROP IN=vlan2 OUT= MAC=4c:ed:fb:d7:9a:84:b0:6e:bf:e4:af:e4:08:00:45:00:00:47 SRC=54.187.190.63 DST=192.168.50.53 LEN=71 TOS=0x00 PREC=0x00 TTL=229 ID=59896 DF PROTO=TCP SPT=443 DPT=61774 SEQ=322819389 ACK=2202403686 WINDOW=118 RES=0x00 ACK PSH URGP=0
Aug 1 00:00:39 WAN Connection: WAN was restored.
Aug 1 00:00:39 ntp: start NTP update
