RT AC3100 - 2.4GHz Radio Disabled After Flashing
Bishoff
Hi guys,
Long time lurker, but newbie to posting. I'm having an issue with my RT AC 3100 and upgrading from 384.6 to 384.13. Since I upgraded, the 2.4GHz band is showing as disabled even though the check box to disable is showing enabled. This is coming off a fresh flash of 384.13. I did the reset to factory default and reboot via the push button switch but i can't seem to get the radio to actually activate. 2.4GHz shows as channel 0 when you mouse over the little wifi icon on the main general page at the top and only one side of the wifi symbol is green.
Router was working fine before the upgrade from 384.6. I actually tried to upgrade from 384.6 about 9 mo ago and I had the same problem, but I can't recall which version of Merlin firmware I was flashing to, but it would have been the current release at the time. Same thing happened with only 1 radio worked, so I flashed back to 384.6 and the problem was fixed. Also, this router has always been on 384.6 which was the very first thing I did when I bought the router was flash it to Merlin's current version at that time. It's been rock stable!
For the 3100 owners out there, have you had this problem? I've seen several posts about the radio being dead but I'm doubtful of that as when I flashed back originally, the problem was fixed. Am I missing something here with settings or is this model maybe not supported any more?
Thanks for any suggestions!
indark
dont have the issue for my ac3100
my suggestion is to power cycle and use the wps method to reset the router.
power off the router for 30 sec+
hold the wps button while powering on, wait till the power led to start blinking/flashing then release the wps button
now wait for the the router finishing booting up.
and then manually reconfigure the router.
Bishoff
Thanks a bunch for the suggestion - I'll give this a shot when I get home today and report back.
Cheers!
OzarkEdge
Part of the Furniture
indark
it is def odd for the 2.4Ghz just stop working like that and comes back when you revert the update.
if it works for 384.6, should work fine with 384.13 without issue.
assuming you dont have anything script / usb drive attaches to the router.
might wanna remove all those before flash and reset the router.
then check to see if 2.4Ghz band works without any of those
can always try the official firmware and see.
and if it does not work with official firmware, i will just try RMA with Asus and get a replacement
Bishoff
I think it is the actual radio after all. I flashed back to 384.6 and had the same problem with the 2.4 radio on CH 0. I then tried the latest official firmware with the same result. I then flashed back to 384.6 and then to 384.13 and the 2.4 radio will not activate. At this point it has to be the radio. Maybe it was sort of on the way out previosuly and the last bit of restarting finally caused a weak component on the radio to finally give out completely.
Such a shame as the unit is just barely under a year old from purchase. Oh well, part of the fun I guess. Thanks all for your suggestions!
Striker317
If it is just barely under a year old, you can do a warranty claim.
