RT-AC3100 Firmware Update 3.0.0.4.384.10007
DragonSpyre
S0 we have another firmware update, here are the specifics from Asus, enjoy!
ASUS RT-AC3100 Firmware version 3.0.0.4.384.10007
New feature
AiMesh: An innovative new router feature that connects multiple ASUS routers to create a whole-home WiFi network. Refer to https://www.asus.com/aimesh/ for more detail.
Security fixed
- Fixed XSS vulnerability. Thanks for Joaquim's contribution.
- Fixed LAN RCE vulnerability. An independent security researcher has reported this vulnerability to Beyond Security’s SecuriTeam Secure Disclosure program
- Fixed remote code execution vulnerability. Thanks to David Maciejak of Fortinet's FortiGuard Labs
Bug fixed
- Fixed NAT throughput drop issue.
- Fixed high CPU loading issue.
- Fixed network map abnormal responded time issues
- Fixed client list issues.
- Fixed AiCloud smart sync issue.
- Fixed USB 3.0 issue. To get full USB 3.0 speed, please disable "reducing USB 3.0 interference".
http://dlcdnet.asus.com/pub/ASUS/wi...732.1689897183.1514955925-52264958.1501471066
Updated a couple of days ago. So far so good :). I wish that AiMesh supports RP-AC68U in the next build.
One thing noticed from the last build. If I login the router using Asus mobile app, "Enable Web Access from WAN" is get enabled. Should it remain disabled?
I have had this build running for 2 days now, and things have actually been running very well so far. The system log now stays really clean compared to releases before this. As a lot of us were hating how much log spam there was being posted in the system log. I haven't noticed any performance issues either. I have AI Protection, and QoS enabled, with NAT acceleration disabled. I actually think this build will be very good for Merlin to work with, once he has the source code of the build.
Well its been right at 4 days for me, and everything seems to been working just fine still. I have noticed with the system log which is much cleaner, with less spam being logged. However there seems to be a issue with the way system log is timestamping things that are logged. As I have seen multiple times, a couple entries in the log being logged with different days, which isn't right. Example I have 4 things logged right now after wiping my log yesterday. Out of the 4, there's two of the same logged. However one shows january 7th, and the other shows january 8th. but they're mixed together, instead of being stacked together with the timestamp they were logged with.
Did you guys do a factory reset moving from Merlin 382.xxx? Thank you!
