Hi all,
Not sure what might be at fault here.
I have a Virginmedia Hub3 in modem mode connected from port 4 to my RT-AC66U.
I can't connect to the router at all it seems. Both Wifi lights are off. All 4 LAN lights and power light are on. The internet light is on static and static green on the port on the hub as well. I have factory reset the Hub3 and can connect to it fine on Wifi and wired connection using the same ethernet cable that goes into the router so know the cable is working.
The SSIDs aren't coming up in available networks before or after the factory reset. It was working fine until some point during the night Tuesday night.
I don't know why I can't see or access the router and why both Wifi lights are off on it?
I'm thinking the router is at fault?
