Got myself a 66U like a month ago, for 2 weeks this traffic analyzer worked fine, on the 22th, after no changes on the router it stopped to work.
Ive turned it off and on, off->restart router->on. Uploading my settings from when i setup the router etc. Not helping at all.
Firmware Version:3.0.0.4.380_4118
Found some thread somewhere that there was something up with it and u could download a beta version to solve it somewhat, after checking the beta firmware on router update it did not find any beta releases. (might be an older thread tho)
Anyone know how to solve this?
It has registered a total of 0bytes since 22th. Between 13th and 21th 1.7tb data has been recorded.
Edit: Got this in system log, its been going on forever...
Aug 12 21:44:21 hour monitor: ntp sync fail, will retry after 120 sec
Aug 12 21:46:21 hour monitor: ntp sync fail, will retry after 120 sec
Aug 12 21:48:21 hour monitor: ntp sync fail, will retry after 120 sec
Aug 12 21:50:21 hour monitor: ntp sync fail, will retry after 120 sec
Aug 12 21:52:21 hour monitor: ntp sync fail, will retry after 120 sec
Aug 12 21:52:51 miniupnpd[32185]: upnp_event_process_notify: connect(192.168.1.234:2869): Connection timed out
Aug 12 21:52:53 miniupnpd[32185]: upnp_event_process_notify: connect(192.168.1.234:2869): Connection timed out
Aug 12 21:54:21 hour monitor: ntp sync fail, will retry after 120 sec
