Armandooooo
Hi all,
I just bought for the first time ever an ASUS router, the GT-AX6000. I am using the release 388_2_2_rog, and I am not familiar with the it yet, hence asking for help.
I have a OpenVPN server in France I want to connect from Australia. It is configured on the server side and I am using OpenVPN GUI from my laptop if I need to establish the connection and is working properly, no issue. My wish is to use the Asus router to connect as a client so I don't need to install OpenVPN GUI everywhere.
It seems at first that the connection is established, because in VPN status tab I get OpenVPN OpenVPN Bridge Freebox - Connected (xx.xx.xxx.xxx tcp-client:60448).
However just below in statistics I see:
I have looked at the systems log and see Initialization Sequence Completed which sounds good.
Below are the logs:
A few things I could not figure out from the different things I red:
Can anyone help?
Thank you
- Public IP "blank"
- Local IP 0.0.0.0
Below are the logs:
Aug 2 21:59:54 rc_service: httpd 3049:notify_rc start_vpnclient1
Aug 2 21:59:54 kernel: br0: port 8(tap11) entered blocking state
Aug 2 21:59:54 kernel: br0: port 8(tap11) entered disabled state
Aug 2 21:59:54 kernel: device tap11 entered promiscuous mode
Aug 2 21:59:54 ovpn-client1[11360]: OpenVPN 2.6.3 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Aug 2 21:59:54 ovpn-client1[11360]: library versions: OpenSSL 1.1.1t 7 Feb 2023, LZO 2.10
Aug 2 21:59:54 ovpn-client1[11361]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Aug 2 21:59:54 ovpn-client1[11361]: TCP/UDP: Preserving recently used remote address: [AF_INET]xx.xx.xxx.xxx:60448
Aug 2 21:59:54 ovpn-client1[11361]: Socket Buffers: R=[131072->131072] S=[16384->16384]
Aug 2 21:59:54 ovpn-client1[11361]: Attempting to establish TCP connection with [AF_INET]xx.xx.xxx.xxx:60448
Aug 2 21:59:54 ovpn-client1[11361]: TCP connection established with [AF_INET]xx.xx.xxx.xxx:60448
Aug 2 21:59:54 ovpn-client1[11361]: TCPv4_CLIENT link local: (not bound)
Aug 2 21:59:54 ovpn-client1[11361]: TCPv4_CLIENT link remote: [AF_INET]xx.xx.xxx.xxx:60448
Aug 2 21:59:55 ovpn-client1[11361]: TLS: Initial packet from [AF_INET]xx.xx.xxx.xxx:60448, sid=4265d38f ea396d0e
Aug 2 21:59:55 ovpn-client1[11361]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Aug 2 21:59:55 ovpn-client1[11361]: VERIFY OK: depth=1, C=FR, O=Freebox SA, CN=Freebox OpenVPN server CA for c6083f3b97f1eee0acd184d0bc441642
Aug 2 21:59:55 ovpn-client1[11361]: VERIFY KU OK
Aug 2 21:59:55 ovpn-client1[11361]: Validating certificate extended key usage
Aug 2 21:59:55 ovpn-client1[11361]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Aug 2 21:59:55 ovpn-client1[11361]: VERIFY EKU OK
Aug 2 21:59:55 ovpn-client1[11361]: VERIFY X509NAME OK: C=FR, O=Freebox SA, CN=Freebox OpenVPN server c6083f3b97f1eee0acd184d0bc441642
Aug 2 21:59:55 ovpn-client1[11361]: VERIFY OK: depth=0, C=FR, O=Freebox SA, CN=Freebox OpenVPN server c6083f3b97f1eee0acd184d0bc441642
Aug 2 21:59:56 ovpn-client1[11361]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA256
Aug 2 21:59:56 ovpn-client1[11361]: [Freebox OpenVPN server] Peer Connection Initiated with [AF_INET]xx.xx.xxx.xxx:60448
Aug 2 21:59:56 ovpn-client1[11361]: TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
Aug 2 21:59:56 ovpn-client1[11361]: TLS: tls_multi_process: initial untrusted session promoted to trusted
Aug 2 21:59:56 ovpn-client1[11361]: PUSH: Received control message: 'PUSH_REPLY,ping 30,ping-restart 120,peer-id 0,cipher AES-256-GCM'
Aug 2 21:59:56 ovpn-client1[11361]: TUN/TAP device tap11 opened
Aug 2 21:59:56 ovpn-client1[11361]: TUN/TAP TX queue length set to 1000
Aug 2 21:59:56 ovpn-client1[11361]: ovpn-up 1 client tap11 1500 0 init
Aug 2 21:59:56 kernel: br0: port 8(tap11) entered blocking state
Aug 2 21:59:56 kernel: br0: port 8(tap11) entered listening state
Aug 2 21:59:56 dnsmasq[3860]: read /etc/hosts - 22 names
Aug 2 21:59:56 dnsmasq[3860]: using nameserver 111.220.1.1#53
Aug 2 21:59:56 dnsmasq[3860]: using nameserver 111.220.2.2#53
Aug 2 21:59:56 ovpn-client1[11361]: Data Channel: cipher 'AES-256-GCM', peer-id: 0
Aug 2 21:59:56 ovpn-client1[11361]: Timers: ping 30, ping-restart 120
Aug 2 21:59:58 ovpn-client1[11361]: NOTE: unable to redirect IPv4 default gateway -- VPN gateway parameter (--route-gateway or --ifconfig) is missing
Aug 2 21:59:58 ovpn-client1[11361]: Initialization Sequence Completed
Aug 2 21:59:59 kernel: br0: port 8(tap11) entered learning state
Aug 2 22:00:01 kernel: br0: port 8(tap11) entered forwarding state
Aug 2 22:00:01 kernel: br0: topology change detected, propagating
Aug 2 22:00:29 dnsmasq-dhcp[3860]: DHCPDISCOVER(br0) 8c:97:ea:0d:aa:35
Aug 2 22:00:29 dnsmasq-dhcp[3860]: DHCPOFFER(br0) 192.168.50.111 8c:97:ea:0d:aa:35
Aug 2 22:00:29 dnsmasq-dhcp[3860]: DHCPREQUEST(br0) 192.168.0.44 8c:97:ea:0d:aa:35
Aug 2 22:00:29 dnsmasq-dhcp[3860]: DHCPNAK(br0) 192.168.0.44 8c:97:ea:0d:aa:35 wrong server-ID
- Redirect Internet traffic through tunnel: I don't see the option "VPN Director" despite having set specific rules
- I tried to put Yes (all) to Redirect Internet traffic through tunnel just to force an see if I will get a local ip adress.
- I have heard on other places that there is bug with the OpenVPN client that if you don't set it the first time correctly, you have to do a hard reset, not sure if this is true.
Can anyone help?
Thank you
