RT-AC68U and Harmony Hub : can't connect internet
jaydee99
I'm trying to setup a Harmony Hub with my asus router and i have some problems.
Hub connects to WiFi but says it's unable to reach the internet when i try to sync it.
I tried with another WiFi network and Hub works fine. All my others WiFi devices connect to internet with my asus router. I tried setting a static ip but it didn't help.
Anyone knows how to fix this ?
Thanx a lot.
I have the Harmony hub and an RT-AC68U and all has worked fine. I have a static IP assigned and I use MAC filtering on my wireless settings.
Ok thanx for sharing your experience.
I think i found what was the problem : OpenVPN. When OpenVPN is on and Redirect Traffic is set to "No", harmony hub works fine and connects to the internet. When i set Redirect Traffic to "Policy Rules", Harmony doesn't connect anymore, even if it's not in the redirect rules. I even tried a rule which set harmony's ip on wan but that didn't help...
Anyone knows what should i do ? Thanx !
Ok i found the answer if this can help someone : changing dns settings in openvpn from strict to exclusive fixed the problem...
