RT-AC68U disconnects but reconnects immediately with an action like ping
gurc4n
Hello network gurus,
I have a Huawei B535-232 modem in bridge mode and RT-AC68U in router mode.
Internet disconnects like 30 minutes later after the setup. If I log in to the Asus management menu and make a ping to google.com, it immediately reconnects.
Is there a way to make keep alive packages on Automatic IP mode bridge connections?
What can I do to overcome this issue?
What firmware version?
It should already be sending period checks to the internet. But additionally you can configure:
Administration - System > Network Monitoring > Ping
It is on the latest Merlin.
I set the modem back to router mode and set the Asus to access point. Since then everything is fine. But I want to use Asus as the router.
