RT-AC68U LAN CLIENT NOT SHOWING, DCHP REVERSATION NOT WORKING
Cosbern
Hi
i have a brand new rt-ac68u, i uploaded immiadetly the latest merlin firmware 384.12.
I think i have a problem or i find a bug: lan clients are not showed in network map i have several client whit static ip wich are showed, other are note same case for dchp client: some are showed some are not or are showed randomly. I can ping EVERY ip from the router and i can ping the router from client.
Second problem, i set a dchp client to a have a mac based assignment, this client is some times shown other not but when it is showed in network map it dosn't use the ip i set (double checked the reservation configuration and mac and everything is fine)
The Network Map is known to have bugs. There's nothing Merlin can do about it because it is closed source, so only Asus can fix it.
