RT-AC68U Major Drama / Bricked :-)
Nutz2U2
Hi Guys,
Well dramas galore with this router that I love so much.
Updated the router to latest Merlin Firmware - then was told to manually turn off / on at the end.
Well that was the last time my baby worked -
Symptom-
Power on - only USB2.0 lights up - without USB drive connected.
Wired LAN lights light up - whenever cable is connected.
Power Light, Wi-Fi, Internet, USB3.0 are all turned off (USB3.0 off even with Drive connected).
Have done factory default reset - reset button and WPS button options - Power Light does not flash.
Then tried the 30 / 30 / 30 reset option - again nothing.
Will be trying the "throw against the wall" option shortly :mad:.
Are there any other emergency reset options I am not aware of ??
Now before anybody gets offensive/defensive - I AM NOT BLAMING THE FIRMWARE - one of the reasons
I bought the ASUS router is because of my appreciation of RMerlin's Firmware over others.
The upgrade tells me it completed but somehow I think the router is maybe "confused".
Any thoughts ???
Thanks for everyone's ideas and help.
BUT IT IS A NO GO.
Time for new router / hub ... With VPN ..
I feel sorry for you, but this happened also to me some time ago with the AC68U: it looked bricked after firmware update. Only the power LED was flashing fast after power on.
Funny enough after some days I tried again and the router booted into the firmware!
I could do a factory reset, but when turned off/on the router to be sure it did not come back online - again fast flashing power LED and nothing else.
So, in my case it looks like a hardware fault - got a new AC87U and I was happy again.
