RT-AC68U & pcsc reader
Nimloth
Hello,
1st of all - hello to this community :)
Recently I bought this nice router and trying to port some applications to it that uses pcsc reader.
When I CC pcc-lite there is problem with generated libs ... system don't see them:
 libpcsclite.so.1 => not found
 libpthread.so.0 => /lib/libpthread.so.0 (0x401af000)
 libdl.so.0 => /lib/libdl.so.0 (0x4014f000)
 librt.so.0 => /lib/librt.so.0 (0x400e5000)
 libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x4015b000)
 libc.so.0 => /lib/libc.so.0 (0x401ef000)
 ld-uClibc.so.0 => /lib/ld-uClibc.so.0 (0x400fe000)
Of course libs exists in system:
admin@RT-AC68U:/tmp/mnt/sda1# ls -la /opt/lib/libpcsc*
-rwxr-xr-x    1 admin    root           962 Mar 15 14:48 /opt/lib/libpcsclite.la
lrwxrwxrwx    1 admin    root            20 Mar 15 14:50 /opt/lib/libpcsclite.so -> libpcsclite.so.1.0.0
lrwxrwxrwx    1 admin    root            20 Mar 15 14:50 /opt/lib/libpcsclite.so.1 -> libpcsclite.so.1.0.0
-rwxr-xr-x    1 admin    root         57012 Mar 15 14:48 /opt/lib/libpcsclite.so.1.0.0
-rwxr-xr-x    1 admin    root           947 Mar 15 14:48 /opt/lib/libpcscspy.la
lrwxrwxrwx    1 admin    root            19 Mar 15 14:50 /opt/lib/libpcscspy.so -> libpcscspy.so.0.0.0
lrwxrwxrwx    1 admin    root            19 Mar 15 14:50 /opt/lib/libpcscspy.so.0 -> libpcscspy.so.0.0.0
-rwxr-xr-x    1 admin    root         16337 Mar 15 14:48 /opt/lib/libpcscspy.so.0.0.0
My CC command:
CC=/media/git/asuswrt-merlin/release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/bin/arm-brcm-linux-uclibcgnueabi-gcc \
CXX=/media/git/asuswrt-merlin/release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/bin/arm-brcm-linux-uclibcgnueabi-g++ \
AR=/media/git/asuswrt-merlin/release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/bin/arm-brcm-linux-uclibcgnueabi-ar \
STRIP=/media/git/asuswrt-merlin/release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/bin/arm-brcm-linux-uclibcgnueabi-strip \
RANLIB=/media/git/asuswrt-merlin/release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/bin/arm-brcm-linux-uclibcgnueabi-ranlib \
ARCH=arm-brcm-linux-uclibcgnueabi  \
CROSS_COMPILE=/media/git/asuswrt-merlin/release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/bin/arm-brcm-linux-uclibcgnueabi- \
CFLAGS='-O2 -Wall -I /media/git/asuswrt-merlin/release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3/arm-brcm-linux-uclibcgnueabi/sysroot/usr/include' \
LIBUSB_CLFAGS="-I/opt/include" \
LIBUSB_LIBS="-L/opt/lib -lusb-1.0" \
./configure --prefix=/opt --host=arm-brcm-linux-uclibcgnueabi --build=i686-pc-linux  --disable-libudev  --enable-libusb
PCSCD deamon created from pcsc-lite works just fine:
admin@RT-AC68U:/tmp/mnt/sda1# pcscd --foreground --debug
00000000 debuglog.c:269:DebugLogSetLevel() debug level=debug
00000403 configfile.l:254:DBGetReaderListDir() Parsing conf directory: /opt/etc/reader.conf.d
00000366 configfile.l:266:DBGetReaderListDir() Skipping non regular file: ..
00000051 configfile.l:266:DBGetReaderListDir() Skipping non regular file: .
00000061 pcscdaemon.c:545:main() pcsc-lite 1.8.10 daemon ready.
00010691 hotplug_libusb.c:515:HPAddHotPluggable() Adding USB device: 3:2:0
00000130 readerfactory.c:989:RFInitializeReader() Attempting startup of OMNIKEY AG CardMan 3121 00 00 using /opt/lib/pcsc/drivers/ifd-ccid.bundle/Contents/Linux/libccid.so
00001776 readerfactory.c:874:RFBindFunctions() Loading IFD Handler 3.0
00000686 ifdhandler.c:1910:init_driver() Driver version: 1.4.15
00003885 ifdhandler.c:1927:init_driver() LogLevel: 0x0003
00000071 ifdhandler.c:1938:init_driver() DriverOptions: 0x0000
00001101 ifdhandler.c:83:CreateChannelByNameOrChannel() Lun: 0, device: usb:076b/3021:libusb-1.0:3:2:0
00000125 ccid_usb.c:281:OpenUSBByName() Using: /opt/lib/pcsc/drivers//ifd-ccid.bundle/Contents/Info.plist
00003485 ccid_usb.c:299:OpenUSBByName() ifdManufacturerString: Ludovic Rousseau (ludovic.rousseau@free.fr)
00000062 ccid_usb.c:300:OpenUSBByName() ifdProductString: Generic CCID driver
00000048 ccid_usb.c:301:OpenUSBByName() Copyright: This driver is protected by terms of the GNU Lesser General Public License version 2.1, or (at your option) any later version.
00003035 ccid_usb.c:589:OpenUSBByName() Found Vendor/Product: 076B/3021 (OMNIKEY AG CardMan 3121)
Thanks for any hint ...
Cheers,
Nimloth
FYI - it's impossible to use external libs as ldconfig is broken ... LOL
Had to build oscam with static libs.
Cheers
