Hello,
I have a couple of questions regarding the Asus RT-AC68U.
1) Does it support adding custom DNS servers for LAN IP addresses? E.g. Every LAN IP would use the ISP's DNS while a single LAN IP uses a custom DNS.
2) Does Download Master support the ability to drop torrent files into some Samba shared directory so that it picks them up to process them? This is much easier than opening up the web interface and uploading the torrent file. I'm using a Mac so I can't download the Windows Download Master tool.
3) Is there an option to enable/disable access to the router settings from the WAN? If so, I want to disable it for security reasons.
4) Is there a way to limit the download/upload speeds of guest networks?
Thanks so much
Thanks so much
