RT-AC86U + 2 Lyra (AiMesh) HELP NEEDED
bbb27
Hello everyone,
I recently purchased an ASUS RT-AC86U to "replace" my ISP own crappy router, and noticed this "new" tech AiMesh that i never heard of. I bought a couple of Lyra routers/nodes, and pair them with my main router. So far so good, but every now and then my wifi gets completely locked to a point that i have to turn off and on my main router again, and sometimes i get very unstable wifi network (connect to SSID but no internet, even if my router saying i have internet connection)...
After reading a bit more, i stumble upon this edited firmware from RMerlin. I decided to give it a try, and in fact it did help, but sometimes i get the locked/unresponsive router.
What i was thinking is if making the 2 Lyra's as Repeater's, with the same SSID and all the stuff as the AiMesh would actually help with this instability instead of using ASUS AiMesh configuration...
I would appreciate any help you guys could give me, since i'm a bit lost here :(
Lyra is known to be troublesome.
Is it only router GUI you cant access, then you could reset GIU with SSH to router and command: service restart_httpd
That's... Unfortunate... So this configuration that i bought is not going to work?? :confused:
Not even the GUI :confused:.
Then, after reseting the Router (usually only the router is enough), i'm back online.
This doesn't happen every single day, but it's ocasionally enough to make me a bit frustrated...
The Router is on latest stable Merlin Firmware (384.13) and the Lyra's are on the latest ASUS official firmware (3.0.0.4.384.46054).
I read some people who had more luck using these nodes as wifi repeater's and skipping the AiMesh configuration, but i really don't know how to properly configure this, since i'm not a network guru :(
