RT-AC86U conflict with Tab A 2019
Fandroid
Bought a Galaxy Tab A 2019 and I'm having problems installing apps on Play Store while connected to RT-AC86U. I can install or update some apps but some others don't start transferring or stop at 99%. When I connect the tablet to a hotspot those apps install or update just fine.
Any ideas? Thanks.
Any ideas? Thanks.
Not sure, but try disabling Airtime Fairness, then Universal Beamforming on the router for the WiFi band being used.
OE
Well, the problem disappeared by itself a few days later with my original configuration of the router... I've no explanation.
Thanks for the help.
Let's blame Android... it's a ridiculous OS.
OE
